How to Optimize Jailbroken Devices
If you have a jailbroken iPhone or iPad, it's very likely that you installed a lot of apps, tweaks and extensions that are now slowing down your device. Now PhoneClean comes to bring an quick and efficient optimizing solution on your iGadget. Read on to find out how to get it done with few clicks.
Part 1: Clean Jailbroken System
Step 1: connect your device to the computer > on the home screen of PhoneClean, click Toolbox button:
Toolbox
Step 2: click System Clean button in the Jailbroken Required section:
System Clean
Step 3: check the junk files you don't need any more and click Clean to remove:
Check Junk Files
Part 2: How to Shrink App Size
Step 1: follow step 1 mentioned above until you find App Shrink:
System Clean
Step 2: choose this option and you'll see which apps contain useless files > after checking all listed files, click Clean to remove:
App Shrink
Still Have Questions Regarding This Guide or PhoneClean? Please Feel Free to Let Us Know. Ask Your Question
