How to Access Files on Android
To learn how to access files on Android device, you can refer to this post. Here, we have mentioned two ultimate ways to access files on your Android phone.
By Faye Clarke | Posted on: Apr. 09, 2019, Last Updated: Apr. 09, 2019
Sometimes, finding files on an Android device can be a quite challenging and frustrating process. Whether you are looking for an mp3 audio file that you don’t see on your music app or an image that you can’t find on your device’s gallery, searching for a file through Android file system is a tricky job. But, in this post, we are going to tell you two simple ways to access files on Android device.
How to Access Files on Android with Built-In File Manager
Now, every Android phone comes with a built-in File Manager that allows users to manage files and folders on their smartphone. Here, you can find all files present on your Android phone, and so, you can explore what files and folders are on your Android phone. You may see this application on your phone with different name knows as File Explorer. What’s more? This file manager let users browse, search, delete, open, copy, share and many more things with their files.
Whenever you want to free up storage space on your Android phone or want to look for a particular file, then you can search out via File Manager of your Android phone.
Here are the steps on how to access files on Android with Android in-built File Manager:
Step 1: To begin with, move to your phone home screen, and look for File Manager or File Explorer application.
Step 2: If you are searching for a particular app’s files, then move to Storage, and here, scroll down until you don’t find the app’s name for which you are looking for a file as shown in the below figure.
How to Access Files on Android with Built-In File Manager - Step 2
How to Access Files on Android with Built-In File Manager – Step 2
Step 3: If you are searching for downloaded files, such as images, mp3, etc, and then, choose “Downloads” option from its homepage. Here, you can view all the files you downloaded on your Android phone.
How to Access Files on Android with Built-In File Manager – Step 3
That’s how you can access files on your Android phone with File Manager. If you still don’t find this as an easy way to look for files, then refer to the next part.
How to Access Files on Android with AnyTrans for Android
Well, how to manage files on Android without many efforts? Then, AnyTrans for Android is the ultimate solution for this. It is an all-in-one and powerful software designed for managing Android content on the computer. Besides content management, it can do much more, for instance, you can transfer data from your Android phone to computer or vice-versa. Undoubtedly, it is the best alternative to the Android in-build File Manager to manage your Android files.
Here are its main features and advantages:
Now, download and install AnyTrans for Android on your computer, and then, follow the below steps on how to manage and access files on Android:
Step 1: Run AnyTrans for Android on your PC, and then, connect your Android phone to the computer using a USB cable or Wi-Fi connection.
Connect with AnyTrans for Android - Step 1
Connect with AnyTrans for Android – Step 1
Step 2: Once you enter into its Files management page, you can view all files present on your Android phone. Here, select the files you want to transfer.
Select the Files You Want to Manage
Step 3: After selecting the files, click on “Save to PC” button to transfer selected files to the computer from your Android phone.
Transfer Selected Files to Computer
Step 4: Once the transfer process is done, you will see a message saying “Transfer completed” on the software interface.
Finish the Process of TransferringFinish the Process of Transferring
So, there is no doubt that both the above ways are great to manage and access files on Android device. But, AnyTrans for Android is one that offers much more than simply managing and accessing the files on Android. In fact, you can manage your Android device data on the computer, i.e. a better way, and instant transfer data from your Android phone to the computer if you want.
Faye Clarke
Member of iMobie_Inc, an enthusiastic fan of Apple and Jazz music, always ready to offer advice and solutions to any iOS & Android related issues.
