How to Access iTunes on Android Phone
If you have your entire media library in the iTunes app on your computer, the following guide should teach you how to access iTunes on your Android phoneiTunesso you can get access to all of your media items on your handheld device. Read on to learn how.
By iMobie | Posted on: Dec. 17, 2018, Last Updated: Dec. 17, 2018
Anyone who has ever used the iTunes app would know that it is one of the best media manager apps available in the market. It has tons of features, a user-friendly interface, and costs nothing to use. Therefore, thousands of users have chosen iTunes to be their main media app and that is where they keep all of their media files.
Sometimes you may want to access your iTunes media on your Android device. While you can always sync your iTunes media with an iOS device using the sync feature, the same does not work for Android phones and you need to use a third-party app to be able to do the task. Fortunately, there is an app called AnyTrans for Android that allows you to access your iTunes media library on an Android phone.
AnyTrans for Android Main Features
AnyTrans for Android is a feature-rich app that enables iTunes fans like you to share your iTunes media library with your Android phones. The app supports a number of media file formats to be transferred from iTunes over to your Android device. The following are some of the main features you get with the AnyTrans for Android app on your device.
In a nutshell, the app lets you copy almost everything you have in iTunes on your computer over to your Android device in just a few clicks.
Download AnyTrans for Android on your Mac or PC and follow the below steps to know how to access iTunes on Android easier than ever.
How to Access iTunes on Android with AnyTrans for Android
The user interface of the said app is so great that you will actually love the process of transferring your content to your device. If you are ready to perform the operation, here is how to access iTunes on Android using the AnyTrans for Android app:
Step 1. Launch AnyTrans for Android on your computer > Enable the USB debugging option on your Android phone if it is not already enabled. Head to Menu > Settings > Developer options and turn on the option that says USB debugging > Then, connect your phone to your computer using a compatible cable.
Step 2. Click on the iTunes icon at the top to access your iTunes media library > You will need to wait while the app loads content from your library.
How to Access iTunes on Android with AnyTrans for Android - Step 2
How to Access iTunes on Android with AnyTrans for Android – Step 2
Step 3. Then, select the content that you want to access on your Android phone and click on the To Android button at the top-right corner to start the transfer process.
How to Access iTunes on Android with AnyTrans for Android - Step 3
How to Access iTunes on Android with AnyTrans for Android – Step 3
Step 4. Wait while the app transfers your selected content over to your Android phone. When all the files have been transferred, you will see the following on your screen.
How to Access iTunes on Android with AnyTrans for Android - Step 4
How to Access iTunes on Android with AnyTrans for Android – Step 4
There you go. That is how you can access iTunes on an Android phone using the most efficient and fastest way available. AnyTrans for Android does more than just letting you copy iTunes library files and the best way to explore all the features of the app is to use it for yourself and find out what it has for you.
If you want to bring your iTunes content on your Android phone, our guide above shows the most efficient way to do that so that you have all the content of iTunes for desktop on your Android device. Download AnyTrans for Android now and manage your Android data in an easier way!
