How to Move Music to SD Card on Samsung Galaxy S7/S5
If you want to transfer your music collection from internal storage over to your SD card, the following guide should teach you how you can move music to an SD card on the Galaxy S7 device. Read on to learn how.
Joy Taylor Last Updated: Mar. 31, 2020
If you have any of the Samsung Galaxy S7 variants, you have at least 32GB of memory space to store your music and other files on your device. For some users, though, this amount of space is not much and they easily use it all up by storing their music collections. If that is the case with you, you may want to move your music to an SD card on your Galaxy S5, Galaxy S7, or any other device you have.
Since the SD cards come in all shapes and sizes, you can easily store from a few hundred music tracks to over a thousand tracks on a good sized SD card. Also, it is pretty easy to move your music from the internal storage of your device over to an SD card. The following teaches exactly how you can do it on your phone.
How to Move Music to SD Card on Samsung Galaxy S7/S5 with My Files App
The great thing about most Samsung phones is that they include an app called My Files that lets users move files between internal and external storages on your device. Your Samsung Galaxy S7 does have the app pre-installed on it and all you need to do is launch it and perform the following steps to move your files to the SD card.
Here’s how to move music to SD card on an Galaxy S5 or S7:
Step 1. Swipe up on the homescreen of your device and tap on the app that says My Files. The app will open.
Step 2. When the My Files app opens, tap on the option that says Audio to move only the music files to your SD card. You may choose other options as well if you want.
How to Move Music to SD Card Galaxy S7/S5 with My Files App - Select Audio
How to Move Music to SD Card Galaxy S7/S5 with My Files App – Select Audio
Step 3. After you have chosen the audio option in the above step, tap on three dots in the top-right corner of your screen and tap on Select. It will let you select the files to be moved to your SD card.
Step 4. Tick-mark all the music tracks that you want to move to your SD card and tap on three-dots and select Move. It will let you move your files.
Step 5. Choose your SD card on the following screen and tap on Done to start transferring your music files to your SD card.
How to Move Music to SD Card Galaxy S7/S5 with My Files App - Move to SD card
How to Move Music to SD Card Galaxy S7/S5 with My Files App – Move to SD card
  1. If you are moving a large number of music tracks from your device over to your SD card, the transfer process will take several minutes to finish. If you are only moving a few songs, you should be done in a few minutes.
  2. Since what you are performing is moving the files, you do not need to delete the files from their original location as the files have been moved and not copied to the specified destination.
How to Move Music to SD Card on Samsung Galaxy S7/S5 with AnyDroid
While the My Files app gets the task done for you, you may be in trouble if you can’t find the app pre-installed on your device. If you have removed bloatware from your phone, the app is likely gone and you will not be able to move your music to your SD card.
And if you are seeking for a tool that enables you to view all your files in one page and move them directly with 1 click, then you should give a try to this Android data manager – AnyDroid that helps you move your music and various other content from your device over to your SD card. It works with almost all the Android devices and allows you to transfer content between internal storage and SD cards on your devices.
There are a few reasons why you may want to consider this app for your music transfer:
  • Fast transfer speed. AnyDroid can help you move 3000 songs from Android to computer within just 5 minutes.
  • It displays all files on your Android phone with categories like music, contacts, messages, photos, videos, etc. So you can easily access all music files on your Android device.
  • Transfer your music files wholly or selectively as you wish. You can choose to transfer all your music files on Android phone as a whole or selectively choose several songs you want to transfer.
  • More than move music files from phone to SD card, AnyDroid enables you to transfer music files and other data from iTunes/iCloud to Android phone, from computer to Android phone and vice versa.
AnyDroid – Android Music Transfer
Want to transfer your music files from Samsung phone to SD card? AnyDroid can be your perfect helper that enables you to transfer all your files from phone to SD card, computer, or another Android device. Keep reading on this post to learn more.
Get it on your computer now, and the following is how you do to move music to SD card on Samsung Galaxy S7/S5.
Step 1. Launch AnyDroid on your computer(PC/Mac). Plug-in your Galaxy S7/S5 to your computer or connect it with your computer via Wi-Fi.
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid - Step 1
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid – Step 1
Step 2. When the app launches, it should recognize your device. Click on the Music option on the main interface of the app. It will let you move music files.
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid - Step 2
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid – Step 2
Step 3. Select the music tracks you would like to move to your SD card and click on the Send to PC button at the top. You should be able to choose your SD card as the destination for your music files.
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid - Step 3
How to Move Music to SD Card Galaxy S7/S5 with AnyDroid – Step 3
Step 4. When all the selected files are transferred, your chosen music tracks are now moved from your Galaxy S7/S5 over to your SD card. You may now use the newly reclaimed memory space on your phone to install new apps or store other files.
If a large collection of your music is lying around on your internal storage, it is recommended that you have it moved to an SD card. The above guide should help you move your music to your SD card using multiple methods. We hope it helps you out. Give a try to this powerful Android data manager now!
Joy Taylor
