2 Ways to Move Files to SD Card on Samsung
Looking for a hassle-free method on how to move files to SD card on Samsung? If yes, then you have come to the right page. Here, we have covered two methods that can help you to move files to SD card on your Samsung phone with ease.
By Faye Clarke | Posted on: Mar. 28, 2019, Last Updated: Mar. 28, 2019
Samsung devices now come with great storage space. Still, there are many users who wish to have unlimited storage space on their smartphones. As we all know that there is no Android phone that comes with limitless storage space, but there are Samsung SD cards that can help you to expand the storage space on your Samsung phone. With the use of an SD card, you can offer more space for your movies, photos app data, etc.
So, if you have some files on a computer or on your phone internal memory, and want to move them to SD Card on your phone, then continue reading this post to know how you can do this. Here, in this post, we have mentioned effective methods for Samsung move files to SD card.
How to Move Files to SD Card on Samsung
There are many ways to move files to SD card on your Samsung phone, but we have listed the easiest ones you are looking for.
Method 1: Move Files to SD Card via AnyTrans for Android
Try AnyTrans for Android and it is a software designed to manage content on Android devices. With the help of this tool, you can easily transfer data to SD card Samsung. What’s more? The software will only take a few minutes to perform this task for you with one single click of a button.
Here are its main features:
Here is the detailed step-by-step guide on how to transfer data to SD card on Samsung with the help of AnyTrans for Android:
Step 1 Download and install AnyTrans for Android on your computer and then, connect your Samsung Android phone to computer with USB cable. You can also download AnyTrans app on your mobile phone to connect your Samsung to computer via Wi-Fi.
Move Files to SD Card via AnyTrans for Android - Step 1
Move Files to SD Card via AnyTrans for Android – Step 1
Step 2When AnyTrans for Android has detected your Samsung, the interface will show as below. Click on the file category or type you want to transfer to SD card. Here we take Music for example.
Move Files to SD Card via AnyTrans for Android - Step 2
Move Files to SD Card via AnyTrans for Android – Step 2
Step 3 Now, click on “Setting” icon located at the upper-right corner of the interface, and then, select your Samsung’s “SD card” as the export destination.
Move Files to SD Card via AnyTrans for Android - Step 3
Move Files to SD Card via AnyTrans for Android – Step 3
Step 4 After that, choose the files you want to transfer then click on the “Send to PC” button to begin the transfer process. Once the process is completed, data will be moved to the SD card on your phone.
Move Files to SD Card via AnyTrans for Android - Step 4
Move Files to SD Card via AnyTrans for Android – Step 4
Method 2: Move Files to SD Card within Samsung Phone
Do you want to move files to SD card within Samsung phone or without using any third-party software? Then, you can easily do this. Here are the steps on how you can do this:
Step 1To begin with, select “Apps” from your phone “Start Screen”. Next, select “Samsung” and then, select “My Files”.
Step 2 After that, select the “My device” option and move to the files or folders you want to transfer to the SD card. For instance, select “Pictures”.
Step 3 Next, select and hold an image or picture. After that, select the pictures you want to transfer and select the “three-dot Options/More” symbol and select “Move”.
Step 4 Here, select “SD card” and select the location where you want to transfer files or folders to. And finally, click on “Done” button.
That’s all on Samsung move files to SD card. Without any doubt, SD cards are a great way to expand storage space not only on Samsung devices but also on other Android phones. With software like AnyTrans for Android, you can easily manage both of your device internal and SD card data. Give a try to it now.
Faye Clarke
Member of iMobie_Inc, an enthusiastic fan of Apple and Jazz music, always ready to offer advice and solutions to any iOS & Android related issues.
