2 Ways to Sync iCloud Calendar with Android
If you wonder how to sync or share calendar data from iCloud to Android, this article is your right choice. We have listed two efficient ways for you to sync iCloud calendar with Android, please keep reading and learn more on it.
Author Avatar Joy Taylor Last Updated: Nov. 03, 2020
Q: “Is there someone who switch from iOS to Android phone? I am wondering how to sync iCloud calendars to Android phone. Because most of my colleagues are using iPhone’s built-in Calendar app to arrange work, but I am using an Android phone… Any suggestions?”
This is a question from an Android forum and there being many other users who have the same problem as this user does. Unlike transferring data from iPhone to Android, sending iCloud data to Android is much more difficult. We have found two methods for users to solve their problems. The first one is syncing with iCloud and Google account, and the other is to take advantage of third-party software – AnyDroid. Keep reading and check more details.
Sync iCloud Calendar with Android via Google Account
With the help of cloud technology, users are able to manage various kinds of data in one place. To sync iCloud calendar, you could take advantage of Google account. Please follow the step-by-step guide below to see how to achieve it.
Step 1. Visit iCloud.com, log in with your Apple ID and password.
Step 2. Click the Calendar on the homepage, then you could see all your iCloud calendar.
Step 3. Choose the calendar event you want to sync to Android, click the share button on the upper right corner. There will be an URL, click copy link.
Step 4. Paste the link to your browser, change “webcal” in the beginning into “https”, then press “Enter” the calendar file will be downloaded to your computer automatically.
Step 5. Visit Google Calendar on your computer, remember to log in with your Google account. Click “Add other calendar” on the left side, then click “Import”.
Step 6. Select file from your computer, find the downloaded calendar file, click “Import” to your Google calendar.
Step 7. Then log in Google Account on your Android device, you could sync calendar to your Android through Google account.
Sync iCloud Calendar with Android via AnyDroid
Although Google account can help users to sync iCloud calendar with Android, the whole process is too complicated and tedious. We recommended a third-party software – AnyDroid to help you sync iCloud calendar in a more convenient way. Here are the reasons why we choose AnyDroid.
  • Easy Operation. To sync iCloud calendar with Android via AnyDroid, you just need a few clicks. The whole process is easy and simple.
  • Powerful Function. AnyDroid not only enables users to sync iCloud calendar, but also other data in iCloud panels, such as Contacts, Photo and Photo Video.
  • Sustainable Use. With AnyDroid, you could manage your device, iCloud and iTunes Library in a systematic way. You could transfer, delete, sync and edit all your Android data within this one software. All long-term device management could take advantage of AnyDroid.
Now just download AnyDroid and follow the guide below to sync iCloud calendar.
Step 1. Install and run AnyDroid on your computer, connect your Android to your computer.
Step 2. When detected your device, click iCloud to Android.
Step 3. Sign in your iCloud with Apple ID and password.
Sign in Your iCloud Account
Step 4. Select Calendar and click Next to the next step.
Step 5. Now AnyDroid is transferring iCloud calendar to your Android device, please wait until the process is finished.
As you can see, compared with these two methods, the second one is much more convenient. If you are interested in it, just download and try AnyDroid.
