How to Transfer Files from Android to PC Using Wi-Fi
Don’t know how to transfer files from Android to PC using Wi-Fi? This post will show you the step-by-step process to transfer files from Android to PC via Wi-Fi.
By Bella Miller | Posted on: Jan. 29, 2019, Last Updated: Apr. 10, 2019
With more and more files stored on the phone storage, our device would slowly become sluggish. To faster the sluggish Android device, move the files that occupying the most storage room to our computer is one good solution.
Transfer Files from Android to PC via Wi-Fi
When it comes to transfer files from Android to PC, the first way that comes to mind is using a USB cable. But constantly plugging in a USB cable can be a hassle.
Then, is there any easy and simple way to complete the job? The answer is absolutely YES. Actually, there are a lot of different options for you to make use of. Here in the following guide, we would like to focus on how to transfer files from Android to PC using Wi-Fi.
The Wi-Fi method of files transfer from Android to PC is efficient and convenient. To finish the task, the most efficient and labor-saving way to is to take advantage of some apps that support Wi-Fi transfer feature. Among so many apps in the market, AnyTrans for Android stands out for its security and below incomparable features.
Now, Free Download AnyTrans for Android on your PC , and then follow the steps below to transfer files from Android to PC via Wi-Fi.
Step 1. Connect Android and PC via Wi-Fi.
Launch AnyTrans on your PC > Go to Google Play Store or other app store to download AnyTrans app on your phone > Open it > Tap on Scanning QR Code to scan the QR code on your PC.
Connect Android and Computer via Wi-Fi
Step 2. Choose transfer mode.
Choose Content to Computer mode to transfer files from your Android device to PC.
Choose Data Transfer Mode
Step 3. Transfer files from Android to PC via Wi-Fi.
Select the file categories you would like to transfer to your PC > Click the Next button to start the process.
With above detailed guide, you may have got the main point on how to transfer files from Android to PC using Wi-Fi. If you will have other transfer needs, such as transferring files or certain files from one Android to another, from computer to Android, or even from iPhone iPad to Android, turn to AnyTrans for Android for help.
Bella Miller
A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
