How to Transfer Files from Android to PC without USB
Looking for ways to transfer files from Android to PC without USB? Here in this article, we’ll show you a simple and safe method to help you out.
By iMobie | Posted on: Jan. 28, 2019, Last Updated: Jan. 28, 2019
Normally, transferring files from Android to PC using a USB cable is the most commonly used method for most users. But there are some shortcomings too. For example, you need to carry with a USB cable anywhere and you need to connect to both your Android device and PC. Let alone that your USB connection may be lost due to unstable network, system crash and more.
Then many users are wondering if there any possibility to transfer files from Android to PC without USB cable? If you are reading this page, then you are the lucky one to get an ideal tool call AnyTrans for Android to help you transfer files from Android to PC without USB cables. Let’s read on this quick tip and get more info.
The Tool You’ll Need – AnyTrans for Android
AnyTrans for Android was developed by iMobie Inc, a certificated Android, and iOS software developer. It aims at managing Android files in an easier and faster way. Here are some highlights of this tool:
  1. Supports transferring files from Android to PC without USB cables, which mean you can move files from Android to PC via WiFi network.
  2. Supports transferring all kinds of Android files like Photos, messages, videos, bookmarks, call history, podcasts, audiobooks and more.
  3. Also, it lets you transfer files from computer to Android, from iPhone to Android and from Android to Android.
  4. It works well on both PC and Mac computer, and you can use common Android devices like Samsung, Sony, LG, HTC, Huawei, Motorola, etc.
Before the start, you need to free download AnyTrans for Android to your PC and then follow the steps below to transfer files from Android to PC without USB.
Step 1: Run AnyTrans for Android on your PC and then free download AnyTrans app to your Android phone. You can get it via http://anytrans.site/ or Google Play.
Step 2: Connect your Android device and PC to the same WiFi network and then scan the QR on the PC screen with your AnyTrans app on Android phones.
Step 3: Then select the files you want to transfer from Android to PC and click on To Computer button to start transferring files from Android to PC without USB.
That’s all for how to transfer files from Android to PC without USB, and you can also try to manage your Android data with it. In addition, you can also transfer files from iPhone to Android or from Android to Android with AnyTrans for Android. Now just get it to your computer and have a free trial >
