How to Transfer iTunes Backup to Android
How to transfer iTunes backup to Android device? Go through this quick guide to learn how you can transfer iTunes backup to your Android phone easily and quickly.
By Abby Walsh | Posted on: Mar. 27, 2019, Last Updated: Mar. 27, 2019
Backing up your important data is the ultimate way to reduce the possibility of data loss. When it comes to keeping iOS data safe, iTunes backup is a great option. And iTunes works very well on syncing data from and to iOS devices. Sadly, when it comes to transferring iTunes backup to Android, you may find it a quite hard thing to do when you switch from iOS to Android device.
But, you don’t have to worry as here we will show you one of the easiest and reliable ways to sync your iTunes to Android phone without much hassle.
The smart way to transfer iTunes backup to your Android phone is using software, like AnyTrans for Android. With the help of this Android data management tool, you can easily transfer data from iTunes to your Android phone. This software is primarily designed to manage your Android device data anywhere and anytime and in any manner you like. No matter where you want to switch data to your new Android phone, whether it is an old phone, iCloud or iTunes, the tool can help you to make the switch better.
Main Features:
Here is the detailed step-by-step guide on how to transfer contacts from iTunes to Android with the help of AnyTrans for Android:
Step 1: Run the software after downloading and installing it on your computer. Next, connect your Android phone to a computer either using a digital cable or Wi-Fi.
AnyTrans for Android - Step 1
AnyTrans for Android – Step 1
Step 2: After that, click on “Android Mover” button from its left menu and then, click on “iTunes backup to Android” option. Next, select an iTunes backup and choose the file type.
AnyTrans for Android - Step 2
AnyTrans for Android – Step 2
Note: if you have protected your iTunes backup with a password, then you have to enter the passcode to gain access to your encrypted backup.
Step 3: After you click the “Next” button, select the file type you want to transfer, such as Contacts to your connected device.  Again, click on the “Next” button to move forward.
AnyTrans for Android - Step 3
AnyTrans for Android – Step 3
Step 4: Now, the software will start the transfer process. Once the transfer process is done, you will get the message saying “Content Transfer Completed”.
AnyTrans for Android - Step 4
AnyTrans for Android – Step 4
As you have seen yourself how much it is easy to iTunes backup to Android with the help of AnyTrans for Android. The software can even help you to transfer data between Android devices. Give a try to it and you will surely get to know how amazing it is for Android users.
Abby Walsh
Member of iMobie team, an Apple fan and a horror movie lover. Always be willing to solve all kinds of Apple-related issues as well as Android's.
