Have you ever received a message on your Android phone, saying “android.process.media has stopped”? If you are faced with this issue, please read this post to figure out why it happens and find the solutions to effectively stop Android process media error.
Every time I boot my phone it gives the error message – Unfortunately, the process android.process.media has stopped. Why and how to fix it?
– An Android User
Android Process Media Has Stopped
Like the iOS operating system, the Android system is not perfect. Despite being one of the most popular operating systems in the mobile industry, it has incurred a series of issues on Android phones such as the settings has stopped unfortunately, the phone has encountered a black screen problem, the phone has stuck in recovery mode, etc. Among these problems, Android.process.media has stopped unexpectedly also frequently occurs in recent days.
If you have encountered this issue and try to get rid of it by yourself, you can find the best answer in this post.
Before learning how do I stop Android.process.media error, you may want to know why you always receive a pop-up window, indicating “Unfortunately, the process android.process.media has stopped.”
In most cases, the Android process media error will happen when an Android phone has been running for a long period. This is because when your Android phone is launched, Android.process.media will run for a while and then transfer into the background program. There are some reasons why android.process.media has taken up CPU all the time and stopped unexpectedly:
You are suggested to spend time solving this issue. If you leave it unsolved, it may lead to a boot loop eventually. In this post, we will introduce 4 solutions to resolve this issue.
To troubleshoot Android.process.media has stopped unexpectedly issue, shutting down and restarting your Android phone will be the first but easiest method worth trying. Since your Android device hasn’t crashed yet, you can simply restart your phone:
Shut Down Your Android Phone
“Power off and restart” differs from “restart”. It will take 10 more seconds to reenter the operating system by directly restarting your device.
Shutting down and restarting the device can completely close all the applications and underlying programs, which can truly give your device a fresh start.
When your Android has been running for a long time, it will generate different kinds of data and cache, occupying the CPU, and leading to processing errors.
Although you can take several tools to remove the redundant data in the operating system, you cannot ensure they are 100% secure.
Clear Data and Cache
As a matter of fact, you can clear overloaded cache and data in the Setting app:
For commonly used apps, you are highly recommended to check its storage and clear cache if necessary:
Check and Clear Data and Cache
By entering into the Android recovery mode, you are allowed to recover and reinstall its operating system. This method can fix the most complicated issues concerning the Android operating system.
Notably, reinstalling the operating system will wipe all the data on your Android phone. Thus, before entering into the recovery mode, make sure you’ve backed up the data on your Android device in advance.
Select the “wipe data/factory reset” Option
The way of entering into the Android recovery mode differs considering the models of Android devices. For most devices, you can access the Recovery mode with the following instructions:
If you find Android recovery mode not working yet, you may need to turn to a technician to get your Android phone repaired.
“Android.process.media has stopped” issue may upset most Android users when using their Android devices. However, in most cases, you can solve the problem by wiping the overloaded data and cache. For this reason, theoretically, you can easily get rid of the problem via the mentioned 4 fixes.
Hopefully, this post can help you out of the problem. If you find it useful, leave a comment, and share it with your friends.
