How to Fix: Facebook Not Working on Android
If Facebook has stopped working on your Android device and you are not sure why, the following post lists some of the fixes you can use to get rid of the Facebook not working on Android issue.
Joy Taylor Last Updated: Apr. 17, 2020
“Facebook app is not working on my moto-g2 android when I open it then it closes down automatically.”
– Dhiraj on Facebook Community
Facebook for Android is one of the apps that often receives new app updates bringing new features and bug-fixes to your devices. However, despite the app getting regular updates, there are occasions where the app stops working or crashes too often. If you are facing a similar issue with the app on your device, you may want to learn how you can get it fixed without much hassle.
In the following guide, you are going to find several methods to fix Facebook not working issue on your Android-based device. The guide covers a variety of fixes that you can apply to your device and get rid of Facebook not working on Android issues without effort. What’s more, all the methods given in the following guide are easy to follow and you should be done in no time.
How to Fix: Facebook Not Working on Android [8 Solutions]
The following are eight of the simple solutions to help you get rid of the issues you are facing with the Facebook app on your Android device.
Method 1. Restart Your Device
The first thing you will want to do is reboot your device and see if that helps fix the issue on your device. This usually works in cases where your phone has been running for an extremely long time without a reboot. Rebooting will clear the RAM of any temporary files and give your phone a fresh start.
Press the Power button on your device and choose Reboot and your device will turn off and turn back on.
Method 2. Log out and Log Back In
Facebook app remembers a lot of things about your account and it saves these details locally in the app on your device. If you are facing an issue where the app crashes too often, you may want to log out of your account in the app to have your personal data removed from it.
Doing so will give a new start to the app on your device. To do this, launch the Facebook app on your phone, tap on three horizontal lines at the top-right corner, scroll all the way down and select the option that says Log Out.
Log Out and Log Back into Facebook App
You will be logged out of your Facebook account. Wait for a minute or two and then log back in using your account credentials and your issue should likely be resolved.
Method 3. Turn Off Power Saver
If you have enabled the power saver or battery saver mode on your device, it may likely be affecting how Facebook works on your device. It may be the case that Facebook requires some resources to properly load but your phone refuses to supply those as it is in the battery saving mode.
Fix: Facebook Not Working - Disable the Power Saver Mode
Fix: Facebook Not Working – Disable the Power Saver Mode
To overcome this, simply disable the power saver mode on your device. This can be done by heading to Settings > Battery > Battery saver and turning the option OFF. Launch the Facebook app and it should work without any issues.
Method 4. Clear Cache Files
Over time the Facebook app on your device collects a lot of cache files. These files are used to quickly serve you with cached content, however, these also cause many slowdowns on the device. Therefore, it is recommended that you get rid of these files every once in a while.
Fix Facebook Not Working on Android - Remove Cache Files
Fix Facebook Not Working on Android – Remove Cache Files
To clear cache for Facebook, open Settings > Apps > Application List > Facebook > Storage and tap on Clear Cache. It will remove all the cache files for the app on your device.
Method 5. Clear App Data
App data is another thing where the data of the Facebook app is stored. This part will accumulate a large number of files if you do not clean it up regularly. Getting rid of files from this part is pretty easy and the following shows how to do it.
Fix Facebook Not Working on Android - Clear Facebook Data
Fix Facebook Not Working on Android – Clear Facebook Data
Head to Settings > Apps > Application List > Facebook > Storage and tap on Clear Data. It will clear all the Facebook app-related data from your Android device.
Method 6. Reinstall the Facebook App
If Facebook still does not work despite clearing cache and app data, you may want to uninstall the app and then install it again from the Play Store. This will clear everything related to the app from your device and you should be able to begin from scratch.
Fix Facebook Not Working on Android - Uninstall Facebook
Fix Facebook Not Working on Android – Uninstall Facebook
Head to Settings > Apps > Application List > Facebook and tap on Uninstall. When the app is uninstalled, install it by launching Play Store and searching for and tapping on Install for the Facebook app. You may have to re-login to your Facebook account but it should certainly resolve all of your issues.
Method 7. Enable Facebook Notifications
Many users complain of not receiving any notifications from the Facebook app on your devices. If that is the case with you, it may be that notifications for Facebook are disabled on your Android device.
Fix Facebook Not Working - Turn on Facebook Notifications
Fix Facebook Not Working – Turn on Facebook Notifications
You can easily enable it, though, by heading to Settings > Apps > Application List > Facebook > Notifications and turning the option ON.
Method 8. Make Memory Space on Your Device
This one is not directly related to the Facebook app on your device but it does affect the Facebook app’s performance on your device. If you are running short on the storage space on your device, Facebook is unable to store its temporary files to properly function. This may cause the app to crash or not respond to your actions.
To overcome the issue, you can uninstall your unused apps and remove unnecessary files to free-up the memory space on your device. Once that is done, launch the app and it should work without any issues.
Bonus Tip: How to Backup Facebook to Computer
Now that Facebook is causing issues on your device, you may want to backup all of your Facebook messages and photos so they are safe and secure in case things go wrong while fixing the app on your device.
AnyDroid is one of the apps that helps you to backup your Facebook content including messages and photos to your computer. The app provides you with an easy way to create a full backup of your content on your computer within a few clicks. Here are some of the features of the app that make backing up Facebook easier on your machine:
  • Select what messages/photos to backup to your computer.
  • Backup all of your messages/photos at once to your computer.
  • Easily restore the backups on your device.
  • Secure transmission of your Facebook data.
Step 1. Free Download AnyDroid on your computer > Launch AnyTrans > Connect your device to your computer by using a USB cable or scanning the QR code.
How to Backup Facebook to Computer – Step 1
Step 2. Click on Apps to get all the apps on your phone.
How to Backup Facebook to Computer – Step 2
Step 3. Choose Facebook > Click on To Computer button to backup Facebook to computer.
How to Backup Facebook to Computer – Step 3
All done. You have successfully backed up your precious Facebook photos to your computer. You may now perform any of the fixes you want on the Facebook app as it will not affect your data since your data is now stored on computer.
If you ever find yourself saying “Facebook is not working today”, you may want to take a look at the above fixes to fix the issues and get the Facebook app to work on your device. We hope the guide helps you get rid of any Facebook related issues on Android.
Joy Taylor
