How to Use Apple Music on Android
Users who don’t know how to use Apple Music on Android, this guide can be helpful to them. In this post, we have shown how you can use and play Apple Music on your Android phone.
Joy Taylor Last Updated: Mar. 31, 2020
Generally, Apple does not provide its services to Android users, but Apple Music is an exception. It means Apple Music is not limited for iPhone users; you can also use and subscribe to this streaming service on your Android device and tablet.
Apple launched an Apple Music for Android since 15th, November of 2015. It is similar to an Apple Music for iOS app, which let you create playlists, and play music purchased from iTunes.
Here, in this post, we will show you how to use and play Apple Music on Android. So, go through this post and also, get to learn how to transfer music from iPhone to Android.
To use an Apple Music on your Android phone, you will need an Apple ID. So, if you don’t have an Apple ID, then you will have to create one to access Apple Music. Amazingly, Apple Music works with Android devices running 4.3 or above.
Unlike Spotify and Google Play Music, Apple Music comes with paid tiers only. However, if you still wish to test its service, then you can sign-up for a free trial. But, you have to provide your payment information. If you don’t cancel the subscription before the free trial ends, then you will be charged automatically for the service. Here are the steps to use and play Apple Music on Android:
Step 1. Download and install Apple Music app on your Android phone from the Google Play Store or Apple official site. You will get a message saying “Welcome to Apple Music”. If it does not appear, then click the “For You” tab.
Step 2. Here, click on the “Free trial offer” option. Next, you need to choose a subscription type i.e. Individual, Student, and Family.
How to Use Apple Music on Android - Step 2
How to Use Apple Music on Android – Step 2
Step 3. If you have an existing Apple ID, then tap on “Use Existing Apple ID” and enter your Apple ID and passcode. Otherwise, tap on “Create New Apple ID”.
How to Use Apple Music on Android - Step 3
How to Use Apple Music on Android – Step 3
Step 4. Now, you need to add a payment method, and then, click on “Join”. Here, you will ask to select genres and artists you like. Once you are done with the above steps, you can access and play millions of songs, create your own playlists and download the latest songs for offline listening.
How to Use Apple Music on Android - Step 4
How to Use Apple Music on Android – Step 4
Bonus Tip: How to Transfer Music from iPhone to Android
If you have switched from iPhone to Android, then you will probably want to transfer your favorite music from iPhone to the new Android phone. Luckily, there are now many good third-party tools available for transferring music from iPhone to Android. But, we strongly recommend that you should rely on AnyDroid whenever you want to move files from iPhone to Android.
  • Save Both Time and Labor. With just 1 click, it helps you transfer all your music from iPhone to Android. It takes only 32 SECONDS to transfer over 3000 songs.
  • Transfer More than Music. Besides music, it also supports to transfer other file types from iPhone to Android, which includes photos, videos, audios, messages, contacts, etc.
  • High Compatibility. It is compatible with all iPhone and Android models. Plus, it also works with all iOS and Android versions.
  • 100% Safe and Secure. Guarantees you that data loss or information leakage would never occur.
Now, Free Download AnyDroid on your computer to have a try. And below are the simple steps to transfer music from iPhone Android.
Step 1: Connect your iPhone and Android phone.
Run AnyTrans on your computer > Connect both your iPhone and Android to the computer using digital cables or Wi-Fi network.
How to Transfer Music from iPhone to Android - Step 1
How to Transfer Music from iPhone to Android – Step 1
Step 2: Choose iOS to Android transfer mode.
Select “Android Mover” option and then, select “iOS to Android” option as shown in the below figure.
How to Transfer Music from iPhone to Android - Step 2
How to Transfer Music from iPhone to Android – Step 2
Step 3: Transfer Music from iPhone to Android.
After that, uncheck other file types, and check Music file type only. Next, tap on “Next” button to begin the transfer process.
How to Transfer Music from iPhone to Android - Step 3
How to Transfer Music from iPhone to Android – Step 3
Now, the software will start transferring music from iPhone to Android, and wait until it is not completed.
Hopefully, this post helps you to understand how to use Apple Music on Android. If you ever want to transfer files, such as music, photos, etc. from iPhone to Android, use AnyDroid. The software will transfer data to your destination device within a few minutes.
Joy Taylor
