Want to transfer data from iTunes to Android device? Continue reading this guide as here we have mentioned numerous iTunes to Android transfer tools that you can use.
Unfortunately, Apple does not provide any reliable solution to transfer data from iTunes to Android. That’s why users need to rely on third-party tools that help them to move iTunes files to Android with ease. Luckily, there are plenty of iTunes to Android transfer tools available for users. As there are many iTunes to Android transfer tools, but we all know that only a few of them works great.
That’s why we come up with several iTunes to Android transfer software to help out users in choosing the most reliable one.
AnyDroid is developed by iMobie to help users in transferring files from iTunes to Android devices smoothly and hassle-free. It is a great tool designed for managing content on Android devices effectively.
When users switch from an old device to a new one, this tool is very beneficial to move the entire old phone data to a new phone in just a few minutes. It has the most intuitive and user-friendly software that makes this software easy to use for beginner users also. Here are its main advantages:
Here is the step-by-step guide on how to transfer data from iTunes to Android with the help of AnyDroid:
Step 1. Download and install AnyDroid on your Mac/PC > Connect your Android phone to the computer using a digital cable.
Step 2. Click on Android Mover and choose iTunes to Android.
Choose the Android Mover on AnyDroid
Step 3. Select files you want to transfer.
Another powerful and reliable iTunes to Android transfer tool is dr. fone – Transfer (Android). It let you transfer songs, podcasts, movies, iTunes U, etc from iTunes to Android without any hitch. With the help of it, you can also transfer music, movies, etc from Android to iTunes. It is considered to be an all-in-one solution to transfer iTunes media to Android devices. It is fully compatible with all Android models and versions. It also lets you move data between the Android device and computer.
When it comes to the downside of software, it does not have many cons, but there is no app available and no wireless data transfer.
2019 Top iTunes to Android Transfer Software Review – dr.fone Transfer (Android)
iSkysoft Phone Transfer is a great software that not only supports iTunes syncing to Android but can also transfer data from one phone to another phone with ease. It has many remarkable features such as it does data backup on computer. It is safe, secure, and risk-free software you can have. It allows users to transfer files from iTunes to Android without data loss and quality loss. It is compatible with almost every Android phone. It offers a one-click feature to backup, restore, transfer and erase device data.
It provides a free trial and thus, you can try out the software feature and can analyze how much useful it is for you. However, it provides some features that do not work properly such as Explorer. It supports limited formats for both audio and videos.
2019 Top iTunes to Android Transfer Software Review – iSkysoft Phone Transfer
Syncios Data Transfer is another great iTunes to Android transfer that can’t be ignored. It helps you transfer iTunes playlists to Android devices. This software is available for both Windows and Mac systems. It can also help you to move data from iPhone to Android and thus, switching data from the old device to a new one becomes easy with this tool. It has other features such as backup device data and restoring data without losing quality. It supports all Android models and versions. It is capable of syncing data from iTunes to a computer.
However, this tool takes a very long time to transfer data from iTunes to Android devices and sometimes, it crashes during the process.
2019 Top iTunes to Android Transfer Software Review – Syncios Data Transfer
That’s all on iTunes to Android transfer review. Now, you know some of the ultimate iTunes to Android transfer ways and you can select any of the above-mentioned software. However, we recommend AnyDroid as it provides all features that other tools offer and many additional features. Download it now and enjoy its super-fast transferring speed.
