How to Set Up and Activate Samsung Galaxy S10
If you have purchased a shiny new Samsung Galaxy S10, you may want to know how to set up Samsung S10 device. It is pretty easy to do that and the following guide shows how to activate Samsung S10.
Author Avatar Joy Taylor Last Updated: Oct. 22, 2020
Whether you buy a new Android device or an iOS device, the first thing you will need to do is set up your device so it starts providing you all the features it has come packed with. The same thing applies to the Samsung Galaxy S10 as well.
If you have bought this brand new phone for yourself or for someone else, you may want to set up and activate your Samsung S10 device. Fortunately, it is fairly easy to set up a Samsung Galaxy S10 device as it works on Android and has a user-friendly interface to get you going. In the following guide, you will learn the exact steps to set up and start using your new phone.
How to Set Up Samsung Galaxy S10
In order to set up your Samsung Galaxy S10, you will need to have your SIM card handy as it will be required to activate the device.
The following are the steps on how to activate Samsung Galaxy S10:
  1. Turn off your phone if it is not already.
  2. Insert your SIM card into your phone and turn your phone on.
  3. You will be asked to choose a language for your phone.
  4. Choose any language that you are comfortable with and continue with the setup procedure.
  5. Your phone will ask you to connect to a WiFi network.
  6. Let your phone scan for the networks.
  7. Tap on your network, enter the password, and you will be connected.
  8. Enter in your Google account details to link your Google account with your new phone.
  9. If you would like to restore a backup, you may do so on the backup screen.
  10. Otherwise, simply continue with the procedure.
  11. You may want to set up a protection method for your account.
  12. Your brand new Samsung Galaxy S10 should now be set up Now.
Set up Samsung Galaxy S10
As you can see, you have set up your device from scratch and so it does not have any of your data on it. However, you can transfer all the data from your old Samsung or any other Android device over to your Galaxy S10 using an easy method. This will save you time that you would otherwise spend downloading content from the Internet.
How to Transfer Data from Old Samsung (Android) to Samsung S10
While there may be other methods to help you move data from an old Samsung phone over to the S10, many of those methods do not offer convenience and flexibility as some professional Android data transfer tools as AnyDroid do.
Enter AnyDroid, an application that allows you to easily transfer data from an old Samsung or any other Android phone over to a Samsung Galaxy S10 device. It works like a charm and gets the whole transfer job done in a few minutes. Here are some incomparable features on Android data transfer:
  • Labor-Saving & Time-Saving. 1 simple click and a few minutes are needed to complete the data transfer job. It takes you only 1 minute to transfer over 1.7GB files between Android devices.
  • Supports Transferring Almost All Files. It supports transferring photos, contacts, apps, messages, videos, music, call logs, documents, ringtones, calendar, books, WhatsApp messages and other up to 24 Android file types.
  • Transfer Only Wanted Files. If you just want to transfer some of your important files from old phone to your new Samsung S10, it also helps you make it easy.
  • Multidirectional Transferring. Besides transferring between Android phones, it also supports transferring from Android to/from Mac/PC, and even from iPhone/iPad/iPod touch to Android.
  • Guarantees you 100% Safe & Security. All files on your device will be kept safe. We can assure you that data loss or information leakage would never occur.
Now, Free Download AnyDroid on your computer firstly, and then follow the simple steps below to transfer data from your old phone to new Samsung S10 effortlessly.
Step 1. Launch AnyDroid and connect both your devices to the computer via USB cable.
Connect your Android Device
Step 2. Move to Android Mover and choose Android to Android transfer. After clicking the “Android to Android” option, AnyDroid will load all your files in source Android phone automatically as below. Then you can choose the data you want to transfer. (“Skip Duplicates” option is selected by default. If you want to keep duplicated files, please uncheck “Skip Duplicates” option.)
Move to Android Mover and Select Data Categories to Transfer
Step 3. When the data has been transferred, you will see the following success message on your screen. AnyDroid has successfully transferred all the data from your old phone over to your new Samsung Galaxy.
Transfer Completed
Transfer Completed
Setting up and activating the Samsung Galaxy S10 phone is pretty easy as you can see in the above guide. The guide also teaches how you can get your existing content on your new phone using an easy to follow transfer method. We hope the guide helps you out.
