How to View Blocked Numbers on Android Phone
Getting tired of prank phone calls from blocked numbers? Read this post to learn how to view blocked numbers on an Android phone.
By iMobie |Posted on: Dec. 27, 2018, Last Updated: Dec. 27, 2018
Sometimes, you will add some phone numbers to the block list, such as some harassment calls, some advertising calls, or phone numbers of some special people like ex-boyfriend or ex-girlfriend, etc. No matter for whatever reasons, after you have added numbers to your blocking list, you can remove or add additional numbers at any time.
The follow-up text will show you how to view blocked numbers on an Android phone, the steps below apply to most Android phones.
Now, follow the below steps to view blocked numbers on your Android phone.
Step 1 On your Android phone, go to the Phone app and select MORE afterward.
View Blocked Numbers on Android Phone - Step 1
View Blocked Numbers on Android Phone – Step 1
Step 2 Tap on Settings.
View Blocked Numbers on Android Phone - Step 2
View Blocked Numbers on Android Phone – Step 2
Step 3 Select Call blocking.
View Blocked Numbers on Android Phone - Step 3
View Blocked Numbers on Android Phone – Step 3
Step 4 Tap on the Block list.
View Blocked Numbers on Android Phone - Step 4
View Blocked Numbers on Android Phone – Step 4
Step 5 From this display, you’ll see the numbers you blocked before. You can add the phone number to the block list by tapping on the “+” button, or press the “-” button to remove existing blocked number from the list.
View Blocked Numbers on Android Phone - Step 5
View Blocked Numbers on Android Phone – Step 5
Bonus Tip: Recover Deleted Contacts on Android Phone
Phone numbers mean a lot for users, if you didn’t add the numbers to the blocked list whereas deleted them, but now you want to retrieve them. Then, how to recover deleted phone numbers on your Android phone?
If you prefer one simple and safe way to retrieve deleted Android phone numbers, then one professional Android data recovery tool – PhoneRescue for Android can be your first choice. And here is the full tutorial about recovering deleted Phone Numbers on Android.
That’s the steps of checking blocked numbers on an Android phone. I think you should be clear about how to view blocked numbers on Android phone. Some phone numbers are really annoying so that you add them to the blocked list, if you want to make some changes someday, you can follow the steps above to make it.
