What Can You Do with A Rooted Android Phone
What is rooting a phone? what does rooted Android phone do? Or what can you do with a rooted Android phone? Read on this guide to get answers.
By Bella Miller | Posted on: Dec. 20, 2018, Last Updated: Sep. 11, 2019
Want to root your Android phone? But, want to have a better understanding of what you can do with a rooted phone prior? You are on the right page. Here, you will get to know interesting things that what can do with a rooted Android phone. First of all, let’s take a look at what rooting a phone is.
What is Rooting A Phone
Rooting an Android phone means having access to more features and functions of a system and can do a lot of tricky things with your phone that is impossible with the unrooted device. In short, rooting your phone can give you superuser access.
What Can You Do with a Rooted Android Phone
1. What Can You Do with A Rooted Android Phone – Block Ads
If you ask Android users who have rooted their phone what does rooting your Android phone do, then the first answer that you will get is block ads. Rooting blocks advertisements from all the apps that are installed on your phone. If you do want to block ads manually from each website or app, then the best solution is rooting your device.
What Can You Do with A Rooted Android Phone - Block Ads
2. What Can You Do with A Rooted Android Phone – Software Update
With the rooted Android phone, you can update your old Android version to the new one. Many Android users root their device for enjoying the latest version and features on their phone. Why use the old version on your phone, you are just a few steps behind from users who have the latest version on their phone.
3. What Can You Do with A Rooted Android Phone – Download Incompatible Apps
Rooting an Android phone allows you to download an app on your phone. Sometimes, you may face a situation when you are failed to install an app like Netflix on your device due to incompatible issues or any other reasons.
What Can You Do with A Rooted Android Phone - Download Incompatible Apps
If you have root access on your phone, you will never face any issue related to incompatible while downloading an app from the Google play store that you want. You can even download those apps that are not available in your region.
4. What Does Rooted Android Phone Do – Enhance Battery Life
Many Android users have complaints regarding battery life and speed. Rooting Android phone let you boost your phone device even when you update software on your phone.
There are many apps available on the internet or Google Play Store for Android. SetCPU is the most used app by many Android users to boost the performance and battery life. So, rooting let you use Android device with great flexibility.
5. What Does Rooted Android Phone Do – Backup Phone Data
Non-rooted users can back up data on their phone, but they can backup only limited type of data such as contacts and only a specific app. However, rooted Android users can backup any kind of data and you can back up everything on your phone if you have root access to your phone.
6. What Does Rooted Android Phone Do – Flash A Custom Kernel
Flashing a custom kernel is the best advantage that Android users can have by rooting their device. It let the communication between your apps and hardware which further boost your device speed and battery life. Even the advanced features like Wi-Fi tethering for unsupported devices can be achieved. From the Google play store, you will get plenty of kernel manager apps for free to use.
If you realise that you do – in fact – need some or all of the files deleted by rooting, just refer to the guide below to get them back easily.
How to Recover Deleted Data on Android after Rooting >
Rooting let you modify your phone’s advanced settings and you can do with your phone whatever you want. It allows you to have full control of your device and you will feel like you own the device. Now, you may have known all the interesting things about what you can do with a rooted phone.
Bella Miller
A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
