Forgot the password of your Samsung tablet? Unlocking the password forcefully can lead to data loss. Here in this article, we will illustrate to you how to unlock a samsung tablet when you forgot the password without losing data.
If you have bought a new tablet or set a new password on your Samsung tablet and forgot it after setting the new password. It will be difficult for you to operate your Samsung tablet as it will not be unlocked easily. But you can unlock it using some tips and tricks.
Here in this post, we will discuss the methods that can help you to know how to unlock a Samsung tablet when you forgot the password without losing data easily and efficiently. You can unlock your Samsung tablet using any of the below-mentioned methods. Read it till the end!
Unlocking a Samsung tablet without a password is a tough task, but you can simply do it using some of the easy methods given below. Read the below methods about how to unlock a Samsung tablet when you forgot the password without losing data.
If you have locked your Samsung tablet and don’t know how to unlock a Samsung tablet when you forgot the password without losing data, then it is the primary option you should use. Unlocking a phone using Google Login is the easiest and simplest way to unlock the phone and we can assure you that there will be no data loss in such a process.
Follow the below-given steps to unlock your Samsung tablet.
Step 1. On the lock screen of your Samsung target, keep entering the wrong password 5 times in a row.
Step 2. Now, click on the ‘Forgot Password’ option given at the bottom of your screen.
Step 3. On the next window, enter the detail of your Google account and Sign in, or you can simply log in using the backup PIN.
Log in using the Backup PIN
These steps can help you to unlock your Samsung tablet.
Further Reading: How to Unlock Samsung Phone If Forgot Pattern and Password >
As Apple and Samsung have their own find my device tool, Google also has its Find My Device tool that can help to know how to unlock a Samsung tablet when you forgot the password without losing data. It is easy and secure to use Google Find My Device on your computer and unlock your Samsung tablet using it.
These steps can help you unlock your phone using Google Find My Device.
Step 1. On your computer, go to a web browser and open Google Find My Device.
Step 2. On the website, you must sign in with the Google Account that was logged in on your Samsung tablet.
Sign in with your Google Account
Step 3. Now, it will display the default device on the left side of your screen. Check if it is yours or not and if not refresh the website.
Step 4. When your device is found, tap on the ‘Lock’ to start the unlocking process.
Tap on the Lock Button
Step 5. Here you can set a new password to change the previous password.
Step 6. Lastly, hit the ‘Lock’ button and your password will be reset.
After following all these steps, now you can unlock your Samsung tablet with the new password you just changed.
If you can’t unlock your Samsung tablet using the above-given methods, then you can use any third-party app to unlock your Samsung tablet. DroidKit – Android Screen Unlocker is one of the best software that you can use to unlock your phone. It can unlock your Android phone in just a few simple and easy steps without any data loss.
You can use these steps to know how to unlock a Samsung tablet when you forgot the password without losing data.
Step 1. Download and Install the DroidKit on your computer and choose the option Screen Unlocker.
Choose Screen Unlocker
Step 2. Use a USB lightning cable to connect your Samsung tablet to the computer > Click the Start tab to start the unlocking process.
Connect your Locked Phone
Step 3. In the next window, confirm your Device Brand and Continue > Then, follow the instructions to put your Samsung tablet into download mode to initiate the recovery mode.
Finish Settings on Samsung
Step 4. Then, DroidKit will remove the screen lock on your Samsung tablet. When the unlock process complete, you can see the interface belwo.
Lock Screen Removal Completed
Here, we have mentioned some of the methods that can help you to resolve the issue of how to unlock a Samsung tablet when you forgot the password without losing data. Using the above-mentioned methods you can simply unlock a Samsung tablet in just a few steps. There is no loss of data while unlocking your phone with the above-given methods.
