3 Ways to Delete Snapchat Messages
Do you want to unsend a snap that you sent mistakenly, but you don’t know how to unsend a snap? Then don’t go anywhere because this guide entails everything; just keep scrolling!!
Author Avatar Joy Taylor Last Updated: Jul. 30, 2021
When you chat on Snapchat, the chat message is automatically deleted after Snapchatters have opened it and left the Chat screen. However, you can schedule the chat message to be deleted after 24 hours. Even though you or your friend has not seen them, Snapchat will delete the messages after 24 hours. However, there is a possibility that you sent a message to the wrong person by mistake. Therefore, you want to delete messages immediately after sending them, even before the receiver sees them.
So, if you’re looking for how to delete a snap video you sent, this is the article for you. Keep reading and get the ways to delete Snapchat messages. Also, you can learn how to recover Snapchat messages if you accidentally deleted some.
Further Reading: How to Recover Deleted Snapchat Data on Android & iPhone >
How to Delete a Snapchat Message you Sent
If you are wondering how to delete Snapchat messages, then look no further. Here is a method for doing it on your phone, whether it’s an iPhone or Android.
Step 1:  In the chat tab, click and hold on the message you want to delete.
Step 2: Click Delete. A confirmation window will pop up.
Step 3: Click the purple Delete button to confirm that you want to delete it.
Note: Your chat buddies will be able to see what you deleted.
Select a Snapchat Message and Click Delete Button
How to Delete the Whole Conversations Snapchat
Some sites find it extremely difficult to delete all of your messages simultaneously. Snapchat, thankfully, is not one of these sites. With a few mouse clicks, you can delete all Snapchat conversations. Here’s how:
Step 1: Open the Snapchat app on your iPhone or Android device.
Step 2: Next, on the home screen, click on the Profile icon.
Click on Profile Icon from Home Screen
Step 3: On the upper right-hand corner, click on the Gear icon.
Click on Gear Icon and Go to Snapchat Settings
Step 4: In Settings, look for Clear Conversations and tap on it.
Tap on Clear Conversations
Step 5: The screen will be filled with a list of all your Snapchat conversations. Select the x icon to the right of each username.
Select the X Button
Select the X Button
Step 6: A notification will appear, asking you to clear the conversation. Just click on Clear, and you are done! Repeat the same for all conversations.
Click on Clear to Confirm Deleting
How to Delete an Unopened Snapchat Picture
Did you mistakenly send a Snap to the wrong person and find that it’s still unopened? Thankfully, you can delete any unopened Snapchat picture. But if you are not sure how to delete an unopened Snapchat picture, then follow the steps outlined below.
Step 1: Open Snapchat and press on the Media you want to delete.
Step 2: You’ll get a pop-up asking if you want to delete or cancel, then just click on delete.
Step 3: The unopened Snapchat picture will now disappear.
Press on Media Files and Click Delete Button
The message will remove when you’ve completed the above steps. But Snapchat will notify the person to whom you sent the image that the message is deleted. They’ll never know what it was because they can never open it.
Bonus Tip: How to Recover Deleted Snapchat Messages
Have you lost your Snapchat messages on your device? Looking for tips to recover those messages? If yes, scroll below to find how you can do the same!
Tip 1: Recover Deleted Snapchat Messages from Cache
If you haven’t saved your messages on your mobile, you’ll have to work a little harder to get them back. Firstly, you can try to find the deleted messages in the cache folder of Snapchat.
The steps below will help you in accessing and viewing the messages.
Step 1: Open file manager, and go to data/data/. Now you can see the /com.snapchat.android/ folder and click it.
Step 2: Click /cache/ folder. You can check if the deleted messages are saved here.
Step 3. If yes, select the messages your want to recover and save them.
Go to Snapchat Cache Folder and Get Back Deleted Messages
Tip 2: Using third- party tool
The next tip for recovering deleted Snapchat messages is by using a third-party recovery software tool. You can use any third-party tool that aids in the recovery of all missing data, including addresses, text messages, images, photographs, call history, records, audios, and Snapchat photos. Using a third-party tool can recover your lost data from any device!
Frequently Asked Questions:
How Can Chat be Automatically Deleted on Snapchat?
Snapchat servers are programmed to remove messages sent in one-on-one Chat until all Snapchat Users have opened and closed the Chat. Messages settings can be set to delete after 24 hours by modifying the erase rules in Chat Settings, and unopened chats are deleted after 30 days.
Can you Unsend a Snap?
When you take a picture or video snaps to send to friends on Snapchat, you can’t undo them once they’re sent. The only option is to delete the message and you can do the same by using the above methods.
When you delete a Snapchat message, can the other person still see it?
As the latest Snapchat update, if you mistakenly send a snap, you can press and hold on to the message to delete it in any chat. A person will no longer see the deleted Snapchat, but they will notify that a message was deleted.
In this post, we discussed different methods relating to the deletion of messages and pictures from Snapchat. Even for a layman, every move mentioned in every part is straightforward to understand. Hopefully, the above methods will help you to delete the messages that you may have sent accidentally or to recover the deleted Snapchat!!
