How to Fix Common Google Drive Problems
Having Google Drive issues or encountered a Google Drive error? In our guide we’ll walk you through a number of the common Google Drive problems and six of the best methods to solve them, so you can get your account back up and running as soon as possible.
By iMobie | Posted: Aug. 14, 2018, Last Updated: Aug. 14, 2018
Home > AnyTrans for Cloud > Cloud Tips > How to Fix Common Google Drive Problems
There’s no telling when you might encounter a Google Drive error; the drive can be working perfectly one minute, only to be completely uncooperative the next. So, what can you do when Google Drive problems strike and leave you unable to access your account?
Luckily, there are plenty of methods that you can use to restore Google Drive, and in our guide, we’re going to be covering a handful of the best.
Google Drive issues range from simple problems that can impact your user experience for a few minutes, to widespread issues that can crash the whole Google Drive system for hours at a time. Some of the most common Google Drive issues include :
Possible Solutions to Fix the Google Drive Problems
If you’ve encountered any of the common Google Drive issues, then we have six solutions that will help you to solve the problem and get back to using your account as normal.
Solution 1. Check the Status of Google Drive
One Google Drive error that can’t be fixed is problems on Google’s side. Your first troubleshooting check should be to look at the status of Google Drive. You can check the status in G Suite Status Dashboard.
Google Drive Problems Solution 1 – Check Google Drive Status
Solution 2. Check Your Internet Connection
You may be encountering problems with Google Drive due to a poor network connection. Checking your connection involves a simple two-step process.
Step 1Open the ‘Settings’ page on your computer.
Step 2Select the ‘Network & Internet’ option. On this page, you’ll be able to see whether you’re connected to the internet.
Google Drive Problems Solution 2 – Check Network
Solution 3. Use Google Drive Files Offline
You can install the Google Docs offline extension on Chrome to save your files when you are connected to the Internet. When all files are saved to your computer, you can view and edit your files as Google Docs, Google Sheets, and Google Slides offline.
Besides, you can also set the sync setting on your Google Drive.
Step 1 Enter your Google Drive on your browser > Click Settings in the top right.
Step 2 Checkbox the option “Sync Google Docs, Sheets, Slides & Drawings files to this computer so that you can edit offline.” > Click Done to save your Google Drive settings.
Google Drive Problems Solution 3 – Use Google Drive Files Offline
Step 3 Then you can edit your files in Google Drive even with no Internet connection.
Solution 4. Clear Cache and Cookies
Clearing your cache and cookies is a great way to solve a number of common problems, including Google Drive issues.
Step 1 Select the three-dot icon in the top right of your browser window > Click ‘More tools’ > Select ‘Clear browsing data’.
Step 2 Select ‘Cookies and other site data’ and ‘Cached images and files’ > Click on ‘Clear data’ button.
Google Drive Problems Solution 4 – Clear Cache and Cookies
Solution 5. Use an Incognito/InPrivate Window
Step 1 Click on the three-dot icon in the top right of your browser window.
Step 2 Select ‘New incognito window’ on Chrome, or ‘New InPrivate window’ on Internet Explorer.
Google Drive Problems Solution 5 – Use Incognito Window
Solution 6. Update Google Drive
Making sure that your Google Drive account is up to date will help to prevent many common Google Drive problems from occurring. Just go to the official website of Google Drive, download the latest version of ‘Backup and Sync’. Then you can have a check whether the Google Drive problem still exists or not.
Google Drive problems, big and small, can be a hassle to deal with when you’re trying to work or store your files online. With our six handy solutions to the common Google Drive problems, you can always make sure that you’re on top of issues when and if they occur.
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
