Why OneDrive Error Code 2 Occurs & How to Fix It
If you’re wondering how to fix the common problem of OneDrive error code 2, then we’ll be walking you through four effective methods, and taking a look at just why error code 2 appears in the first place.
By iMobie | Posted: Aug. 01, 2018, Last Updated: Aug. 01, 2018
Home > AnyTrans > AnyTrans for Cloud > How to Fix OneDrive Error Code 2
OneDrive error code 2 is a problem that occurs when OneDrive has trouble retrieving the details from your account. If you experience this problem, then you’ll be unable to use OneDrive or access the files that you have stored in the drive.
In this article, we’ll help you to identify the possible causes of OneDrive error code 2 and look at multiple methods for how to fix OneDrive error code 2 when it occurs.
Why Does the OneDrive Error Code 2 Appear
There are multiple reasons why you may be experiencing problems with OneDrive error code 2. Many OneDrive error codes are the result of syncing problems that can occur when you try to sign into your account. The problem can also be the result of issues with account authentication.
In instances where the OneDrive error code 2 only appears for a short period of time, the issue can be the result of a temporary problem or malfunction in the system.
We’ll be looking at four common methods for how to fix OneDrive error code 2, that will hopefully be able to provide you with access to your OneDrive account as quickly as possible.
Method 1: Restart Your Device and Check Connectivity
The first step for how to fix OneDrive error code 2 is to restart your device and then make sure that the internet connection on the device is strong. If there is no internet connection, then try to access your account from another device and see if the problem persists.
Method 2: View the Status of Microsoft Office
If you’re still encountering OneDrive error code 2, then check the current status of the online services for Microsoft. If there is an error in the system, then the problem that’s occurring may only be a temporary issue and not a problem with just your account. If there is an issue with OneDrive, then you’ll need to wait until the problem is solved.
Fix OneDrive Error Code 2 - Check Status of Microsoft Office
Fix OneDrive Error Code 2 – Check Status of Microsoft Office
Method 3: Sign into Your Microsoft Account
If there are no evident problems with OneDrive, then the problem may be concerning your account. The next step is to sign into your Microsoft account and see if there are any problems with authentication. If there are no authentication issues and you have no trouble accessing other services that Microsoft offers, then the issue will likely just be temporary.
From the Microsoft website, you’ll also be able to troubleshoot problems with OneDrive syncing. First, sign into your account and visit the OneDrive help center.
Fix OneDrive Error Code 2 - Sign into Microsoft Account
Fix OneDrive Error Code 2 – Sign into Microsoft Account
Then, select the “Troubleshoot” option, and choose “Fix OneDrive Sync Problems”.
Fix OneDrive Error Code 2 - Fix OneDrive Sync Problems
Fix OneDrive Error Code 2 – Fix OneDrive Sync Problems
Method 4: Contact Tech Support
If you still can’t sign into any of your Microsoft services, then the problem that you’re experiencing may be to do with a completely different issue. If the first three methods haven’t worked for you, then you’ll need to contact Microsoft tech support. The support team will require information regarding your server address, the error code, and information about the further problems with your account.
You can contact support from your Microsoft account, where you’ll be asked to provide a description of the problem that you’re having.
Fix OneDrive Error Code 2 - Contact Tech Support
Fix OneDrive Error Code 2 – Contact Tech Support
Many OneDrive errors can be fixed with a simple connectivity check or device restart, or in the case of temporary OneDrive problems, by waiting for the issue to be resolved. For issues that can’t be resolved in this way, checking the status of your Microsoft authentication is one of the quickest fixes for how to fix OneDrive error code 2.
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
