How to Add A Document from iPhone to Dropbox
If you want to create a backup of your important documents, the best option is to add a document to Dropbox. In this article, we are providing you the ideal way on how to add a document to Dropbox.
By iMobie | Posted: Jul. 25, 2018, Last Updated: Jul. 25, 2018
Home > AnyTrans for Cloud > Cloud Transfer > How to Add A Document from iPhone to Dropbox
Dropbox has become a very popular storage system. You can save multiple files on Dropbox at one time. It supports various file types such as images, videos, and many other files. For professional people, Dropbox is a very useful system to store their work files. Once you add documents into  Dropbox, you can access these documents from anywhere or anytime when you have good internet connection.
Dropbox is also considered the ultimate internet application. You can also use Dropbox to share files with others. It has multiple features that you can use in the right way to get a benefit from it. If you want to learn how to add a document from iPhone/iPad/iPod to Dropbox, then below we are giving you the reliable ways for adding documents to Dropbox.
How to Add Documents from iPhone/iPad/iPod to Dropbox With Ease
There are two ways to add a document to Dropbox. Both the ways are simple and can add a document within a few minutes with having a good access to the internet. Below both the ways are described in details:
Way 1: How to Add a Document to Dropbox via App
Step 1: If the Dropbox app is installed into your device, then check if you are log on into your Dropbox account. If you are not, then log-in into your account. If you do not have an app on your device, then you can install from the “Apple Store”.
Step 2: After log-in to your Dropbox account, click on the “+” icon to start.
Step 3: Now, you will get three options. Choose the “Create or Upload File” option to add a document to Dropbox. Select the document that you want to add.
How to Add a Document to Dropbox via App – Step 3
Step 4: Tap on”Save to Dropbox”: After choosing the desired document, click on the “Save to Dropbox” as shown below:
Step 5: Click on “Save”: Eventually, to add a document to Dropbox, tap on the “Save” icon.
Way 2: How to Add a Document to Dropbox via Website
If you want to know how to add a document from iPhone/iPad/iPod to Dropbox through its website. Then, follow the below instructions:
Step 1: After opening the dropbox official website on the browser, tap on the “Sign in” option to enter into dropbox.
How to Add a Document to Dropbox via Website – Step 1
Step 2: Now, enter your login details or you can also sign in with your Google account.
Step 3: After Sign in, select the “Upload” button to add a document from your device.
Step 4: Now, tap on “Files” and select your document from your attached device to the computer to add.
Step 5: After selecting the document, click on the “Dropbox” and then “Upload” and your document will be added to your Dropbox account.
The above methods on how to add a document from iPhone/iPad/iPod to Dropbox is one of the simplest methods. And AnyTrans for Cloud can help you manage multiple cloud drives at one place.Just get it now and start manage your cloud drives easily >
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
