How to Download Documents from Dropbox
If you want to learn how to download documents from Dropbox, then in this article we have shared the most simple and easy method to download the documents to your phone or PC.
By iMobie | Posted: Jul. 17, 2018, Last Updated: Jul. 17, 2018
Home > AnyTrans for Cloud > Cloud Transfer > How to Download Documents from Dropbox
Dropbox is one of the best cloud services that is specifically designed to be an external storage space for the users. It is basically a backup method for all the data files present in your phone, tablet, or Computer. The main reason to provide all these backup space is to ensure that if anytime your phone has an issue or you have a risk of losing your data, then you can save those data files into the Dropbox. Dropbox will have a recovery of your files.
So, if you have lost your photos, videos, music and most importantly, your document files, then use Dropbox to recover them and get them on your device. To know how to download documents from Dropbox, refer to this article and get your documents or any other file on your phone or PC.
There are two simple methods to download documents from Dropbox, one is from their app and the second one is from their website. Both of these methods are explained below:
Method 1. Dropbox App:
To find out how to download documents from Dropbox, get the Dropbox app on your phone and then get your documents to your phone or PC in a few simple steps. The step by step guide to download documents is given below:
Step 1. Download the Dropbox app from their website on your phone or PC. Sign in to your Dropbox account using valid credentials.
Step 2. Open the location of the files where it is stored. You will see an (…) option. Click on the option.
How to Download Documents from Dropbox via App - Step 2
How to Download Documents from Dropbox via App – Step 2
Step 3. A drop-down menu will appear. Select the download option and the document will be successfully downloaded to the default folder in PC.
Step 4. If you are using a phone app, then you will see multiple options. Choose the export option, and select save to device to download the document. And it will be saved on the device storage.
How to Download Documents from Dropbox via App - Step 4
How to Download Documents from Dropbox via App – Step 4
Method 2. Dropbox Website:
The Dropbox official website can be accessed from any browser. It doesn’t occupy any space on your phone and hence it is preferred by many users. To download documents directly from the website to your PC or Phone, follow the step by step guide:
Step 1. Go to the official website of Dropbox. Sign in using your email and password.
 How to Download Documents from Dropbox via Website-Step 1
Step 2. Then on the homepage of the website, find the document you want to download.
How to Download Documents from Dropbox via Website-Step 2
Step 3. Once you find the document, you will see an (…) option. Click on that option. And select the download button. The document will be downloaded in the default folder of PC. You can also specify the storage space if you are using the phone.
How to Download Documents from Dropbox via Website-Step 3
Method 3. AnyTrans for Cloud
AnyTrans for Cloud is a smart and secure cloud management tool, which can help you manage multiple cloud drive in one place with one single login. Check some features below:
1. Supports downloading documents from Dropbox within steps in an easy way.
2. Supports managing multiple cloud drives like Google Drive, Dropbox, OneDrive, pCloud, iCloud, Box and more in one place.
3. Allows users to transfer files from one cloud drive to another without any limitation, which makes it quite convenient to move data between cloud drives.
Now just free sign up  AnyTrans for Cloud and download documents from Dropbox quickly.
Step 1. Log in AnyTrans for Cloud and click Add Cloud on the homepage. Then click Dropbox and then authorize it to access your Dropbox account.
Download Documents from Dropbox via AnyTrans for Cloud – Step 1
Step 2. Click Dropbox on the left sidebar and select the documents you want to download > click on Download button and then it’ll start downloading now.
Download Documents from Dropbox via AnyTrans for Cloud – Step 2
We briefly provided you with a guide on how to download documents from Dropbox. Now you are free to choose any of the above-explained methods to get your documents to your device. Whether it’s the Dropbox website or the app, both of the methods will enable you to access your files anytime anywhere. And AnyTrans for Cloud will be a great helper to download documents from Dropbox as well as other cloud drives. Just get this free tool and try it now!
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
