How to Move Photos from iPhone to Dropbox
If you are looking for a solution to import iPad photos to Dropbox or download them, then here is a proper and step by step guide to do it. The process is simplified for better understanding.
By iMobie | Posted: Jun. 25, 2018, Last Updated: Jul. 24, 2018
Home > AnyTrans for Cloud > Cloud Transfer > How to Move Photos from iPhone to Dropbox
Dropbox is the service which enables a user to upload and retrieve data from an external storage source according to their requirements. Dropbox offers Cloud Storage, File Sync, and a personal cloud to store data.
If you are looking for an article to tell you how to move photos from iPhone to Dropbox, then your search ends here.
The easiest way to import iPhone photos to Dropbox is to directly upload the data in the Dropbox automatically. There is also a manual way to do it. The manual option is available so that no redundant data will be stored in the Dropbox.
Method 1. Using the Website:
Open the official Dropbox website from your phone and then follow the steps.
Step 1. Sign up on the website if you don’t have a Dropbox account. You can use your existing email id and password.
Step 2. Log in and navigate to the folder or photo you want to upload.
Step 3. You can upload the photo in the main directory or you can create a new folder. Then select Upload.
Step 4. Click on the Choose Files Option and select the photo you want to upload. You can add multiple files at the same time.
Move Photos from iPhone to Dropbox Using Website - Step 4
Move Photos from iPhone to Dropbox Using Website – Step 4
Step 5. Click on start Upload and your photo will be moved from your iPhone to the Dropbox within minutes.
Method 2. Using the App:
Step 1. Install the Dropbox app from the App Store.
Step 2. Open the app and select sign in if you have an account. Otherwise, click on the sign-up or create an account option.
Step 3. Log in to the account. You will see a + sign on the homepage. Select the + SIGN.
Move Photos from iPhone to Dropbox Using - Step 3
Move Photos from iPhone to Dropbox Using – Step 3
Step  4. Choose the create or Upload File option.
Step 5. Select the file you wish to move and click on Upload Files.
In this article, two methods to move or upload photos from iPhone to Dropbox are described. Now you know how to download iPhone photos to Dropbox. Go ahead and link your data with Dropbox to have a backup for your photos, videos, documents, or any other file. And AnyTrans for Cloud will be your great helper to manage multiple cloud accounts. Just register it and have a free trial >
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
