How to Save Documents to Dropbox from iPhone/iPad/iPod
If you want to know how to save documents to Dropbox, the guide can do you a favor. 3 ways will be offered to help you save documents from iPhone, iPad or iPod to Dropbox.
By iMobie | Posted: Jul. 24, 2018, Last Updated: Jul. 24, 2018
Home > AnyTrans for Cloud > Cloud Transfer > How to Save Documents to Dropbox from iPhone/iPad/iPod
Dropbox is a cloud drive that provides cloud storage and file sharing service. With documents stored on Dropbox, you can save a lot of space for your device. Windows, Mac and Linux, or the iOS and Android mobile phone are supported. More importantly, Dropbox syncs your documents and files across all of your devices, so you can access everything, everywhere. In the article, we share 3 solutions on how to save documents to Dropbox from iPhone/iPad/iPod. You can save documents to Dropbox within a few minutes by using below-mentioned ways. We use iPhone as the example.
Part 1. How to Save Documents to Dropbox from iPhone via Dropbox App
Step 1 To start the saving process, you need to download the app from Apple Store. After installing the app, launch it and log into your Dropbox account.
Step 2 You will see the “+” icon. Tap on it and click on “Create or Upload File” option.
Save Documents to Dropbox from iPhone via Dropbox App - Step 2
Save Documents to Dropbox from iPhone via Dropbox App – Step 2
Step 3 Now, find and select the desired document that you want to save to Dropbox. Then click on “Save to Dropbox” to complete the process.
Step 4 Click on “Save” option and then your documents will be saved to Dropbox.
Save Documents to Dropbox from iPhone via Dropbox App - Step 4
Save Documents to Dropbox from iPhone via Dropbox App – Step 4
Part 2. How to Save Documents to Dropbox from iPhone via Dropbox Website
Before the detailed steps to save documents from iPhone to Dropbox via the website, you need to export iPhone documents to computer firstly. The guide about how to transfer files from iPhone to computer can be helpful.
Step 1 Go to the Dropbox official site and log into your Dropbox account.
Step 2 Go to “Files” from the left sidebar. You can create a new folder to store the Documents from your iPhone. Then hit the “Upload” button.
Save Documents to Dropbox from iPhone via Dropbox Website – Step 2
Step 3 Now, click on “Files” to select the document from your device.
Save Documents to Dropbox from iPhone via Dropbox Website – Step 3
Part 3. How to Save Documents to Dropbox from iPhone via AnyTrans for Cloud
Here AnyTrans for Cloud is also recommended for you to save documents to Dropbox. AnyTrans for Cloud is a multifunctional cloud manager that enables you to access and manage files and documents on your Cloud Drive. Dropbox, Google Drive, OneDrive, Box, iCloud Drive, pCloud, and more are supported. Check what does the tool can do for you:
  1. Multithreading technology ensures fast speed to save documents to Dropbox.
  2. 100% privacy and security guarantee keeps your Dropbox account info and all documents and files private and secure.
  3. Flexible file sharing channels enable you to share cloud files and folder via email, Facebook, Twitter, Google+, message, or WhatsApp.
  4. Cloud Migration feature allows you to move files and folder from one cloud to another directly with simple steps.
Then sign up for AnyTrans for Cloud to start the steps to save documents to Dropbox. And please make sure you have exported the documents from iPhone to computer. If not, do as the instructions about how to transfer files from iPhone to computer.
Step 1 Download and install AnyTrans for Cloud app on computer. Open it and log into your AnyTrans account.
Save Documents to Dropbox from iPhone via AnyTrans for Cloud – Step 1
Step 2 Click on the “+” button and choose Dropbox to add to AnyTrans for Cloud. And follow the screen instructions to finish the authorization.
Save Documents to Dropbox from iPhone via AnyTrans for Cloud – Step 2
Step 3 Hit the Dropbox icon on the left sidebar. Click “Upload” button and select the documents that you want to save to Dropbox.
Save Documents to Dropbox from iPhone via AnyTrans for Cloud – Step 3
In this article, there are three ways to save documents to Dropbox from iPhone, iPad or iPod touch for you to choose from. For any doubts, welcome to write down in the comments below. If you have more than cloud drives, AnyTrans for Cloud is strongly recommended, with which you are able to access and manage multiple clouds within just one login. Here free sign up for AnyTrans for Cloud to have a try >
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
