How to Transfer Files from Dropbox to OneDrive
Wondering how to migrate Dropbox to OneDrive in an easy way? Here in this article, we’ll show you a useful method to make it within steps.
By iMobie | Posted: May. 31, 2018, Last Updated: Jul. 18, 2018
Home > AnyTrans for Cloud > Cloud Transfer > How to Transfer Files from Dropbox to OneDrive
“How can I move files from Dropbox to OneDrive? I want to move files from Dropbox to Microsoft OneDrive, sometimes I want to transfer files from OneDrive to Dropbox. How can I realize this? Any tool suggestions? Thanks.”
A user from Quora
Like this user, you may also want to migrate files from Dropbox to OneDrive, especially after OneDrive being baked into an Office 365 subscription presenting 1TB of storage, which potentially represents much better value. You can transfer Dropbox to OneDrive with the old drag-and-drop way, and also you can try this simple and safe tool called AnyTrans for Cloud to make your transfer process simpler than ever.
Part 1. How to Migrate Dropbox to OneDrive in Traditional Way – Download and Upload
Step 1. Just go to the web page of Dropbox and sign in your account. Select the files you want to migrate to OneDrive and then download them to local hard disk.
How to Migrate Dropbox to OneDrive via Traditional Way – Step 1
Step 2. Log into your Microsoft OneDrive and click the Upload button to upload files or folder you just download from Dropbox.
How to Migrate Dropbox to OneDrive via Traditional Way – Step 2
Part 2. How to Migrate Dropbox to OneDrive in an Effective Way – AnyTrans for Cloud
Want to find a better way to migrate Dropbox to OneDrive without the downloading and uploading process? Here we’ll show you an impressive tool called AnyTrans for Cloud to help you make it in a simple way. Now let’s check some features of it:
  1. Supports migrating Dropbox to OneDrive directly without downloading and uploading process, which makes it quite simple to move files between cloud drives.
  2. Supports managing multiple cloud drives like Dropbox, OneDrive, Google Drive, pCloud, iCloud, Box and more with one single login.
  3. Allows you to share content with your friends via a link and you can encrypt your files and delete this link as you want.
Now just free sign up AnyTrans for Cloud and follow the steps to migrate Dropbox to OneDrive within simple steps.
Step 1. Login in AnyTrans for Cloud and click Add New button > Add Cloud. Then add Dropbox and OneDrive account to one place.
 How to Migrate Dropbox to OneDrive in an Effective Way – Step 1
Step 2. Click on Dropbox from the left sidebar > select the files you want to migrate from Dropbox to OneDrive > Sync to Cloud.
 How to Migrate Dropbox to OneDrive in an Effective Way – Step 2
Step 3. Choose OneDrive as your target cloud drive and click on Next to create a sync task to migrate Dropbox to OneDrive.
How to Migrate Dropbox to OneDrive in an Effective Way – Step 3
Isn’t is easy to transfer data from Dropbox to OneDrive with the help of AnyTrans for Cloud? What’s more, you can also manage other cloud drives like iCloud, FTP, Google Drive, Box, etc. Just register it for free and have a trial now >
AnyTrans ® for Cloud
The best tool to meet all needs for cloud data management, like migrating between different clouds, adding files on mobile and computer to cloud, downloading cloud data to mobile and PC/Mac. All Cloud Brands Supported.
Sign Up Now
  • * 100% Free and Safe
