How about Get Audio from iPod nano 5G to iPhone 4S
iMobie Support Team share their tips on how to Get Audio from iPod nano 5G to iPhone 4S. Read on to find a simple and instant solution about Audio from iPod nano 5G to iPhone 4S.
Vicky
Apr. 02, 2015
Your Ultimate iPhone, iPod, iPad Manager
Free download this award-winning software so that you can make use of it after reading this article.
iPhone 4S
Letter from iMobie User:
I got a new computer because I broke my old one. It's Sony VAIO, and I need to get audio from iPod nano 5G to iPhone 4S (as well as the new computer). But all of my audio is "Downloaded from my old iPods" how can I get audio from iPod nano 5G to iPhone 4S without having to redownload all my audio? Thanks for all your help.
Related iPod Article: How to Transfer iPod Music to Computer
Answer from iMobie Team:
It's not likely that you can get audio from iPod nano 5G to iPhone 4S with iTunes, even though you are an experienced user. You may wonder if iCloud is worth a try? Yes, but only when you get favorable network connection. Accordingly, it is recommanded to use a decent third party audio Transfer application. Take AnyTrans as an example. It can help you to get audio from iPod nano 5G to iPhone 4S with a few clicks, and you even don't have to bring up slow and clunky iTunes.
As long as you keep using iTunes, you'll find it is impossible to get audio transferred among multiple devices. At this moment, you can simply find a versatile iTunes Alternative for iPhone/iPad/iPod management. We recommand you AnyTrans because of its flexibility. Thanks to supporting multiple devices at once, it will move audio from iPod nano 5G to iPhone 4S with one single click.
Also Read: How to Transfer Photos from Computer to iPhone 7 >
How about Get Audio from iPod nano 5G to iPhone 4S by Using AnyTrans
First of all, AnyTrans is completely clean and safe to use. You can get it here. And after few seconds installation, you can make use of it by following steps. Below is the main interface of AnyTrans.
How to Use AnyTrans to Get Audio
Step 1:
Connect your iPod nano 5G and iPhone 4S with computer via USB cables. AnyTrans will automatically load all media content on your devices and also iTunes library. You can also give it a check on how many free space remains. Learn how to get more space on iPhone iPad iPod touch
Step 2:
Click on "Audio Books" to enter the manage page.
Step 3:
Highlight the audio files you choosed and click To Device option (Shortcut: Right click the mouse and select To Device). Then you can leave it alone and AnyTrans will auto get audio from iPod nano 5G to iPhone 4S.
Don't Forget to Share This Article with Your Friends
Related external source
  • iPhone 4S - The iPhone 4S is a touchscreen-based smartphone developed by Apple Inc. It is the fifth generation of the iPhone and retains the exterior design of its predecessor.
  • iPod shuffle 1G - New entry-level model. Uses flash memory and has no screen.
