Can I Rip iTunes U from iPod classic to iPod nano 7G
Learn how to Rip iTunes U from iPod classic to iPod nano 7G. This page will give you a simple software that can help you Rip iTunes U from iPod classic 6G to iPod nano 7G.
Jason Zhang
Apr. 14, 2015
Follow @JasonZh20
All-in-one iPhone, iPod, iPad Manager
Free download this award-winning software so that you can make use of it after reading this article.
iPod nano 7G
Letter from iMobie User:
I have iPod classic 6G with a bunch of iTunes U files. Now I have got a new iPod nano 7G saved onto my computer with iTunes. I am trying to rip iTunes U from iPod classic 6G to iPod nano 7G, But I can't figure out how. I'm very frustrated that iTunes just doesn't support to transfer my own music from iPod back to computer.
Answer from iMobie Team:
Just get a new iPod nano 7G and want to rip iTunes U from iPod classic to the new one? Apple iTunes gives a general solution for syncing iTunes library with iPod nano 7G but probably you still need a third party tool to rip iTunes U from iPod classic to iPod nano 7G. In the following iMobie guide, you'll get an answer.
As long as you keep using iTunes, you'll find it is impossible to get iTunes U transferred among multiple devices. At this moment, you can simply find a versatile iTunes Alternative for iPhone/iPad/iPod management. We recommand you AnyTrans because of its flexibility. Thanks to supporting multiple devices at once, it will move iTunes U from iPod classic to iPod nano 7G with one single click.
How about Rip iTunes U from iPod classic 6G to iPod nano 7G by Using AnyTrans
Before starting, you can free download AnyTrans and get it installed on your computer. It is worry-free from virus or any other potential security hazards to your PC. After a few seconds setting up process, you can check it's main interface:
How to Use AnyTrans to Rip iTunes U
Step 1:
Use two or more USB cables to Connect your iPod classic and iPod nano 7G with computer. Wait a second and AnyTrans will automatically show up the basic info of your devices. You can also check how much free space remains through the Usage bar. Learn how to reclaim storage space on iPhone iPad iPod touch
Step 2:
AnyTrans will indicate your devices on the top side. Choose iPod classic and click its iTunes U tab on the left side of the window and you'll review the relevant media contents.
Step 3:
Highlight the iTunes U files you choosed and click To Device option (Shortcut: Right click the mouse and select To Device). Then you can leave it alone and AnyTrans will auto rip iTunes U from iPod classic to iPod nano 7G.
Don't Forget to Share This Article with Your Friends
Related external source
  • iPod shuffle 3G - Smaller design with controls relocated to right earbud cable. Introduced with two colors, and features VoiceOver.
  • Apple Inc. - Apple official site.
