How to Transfer Files from PC to iPhone without iTunes
Want to know how to transfer files from PC to iPhone without iTunes? This guide will tell you quick and easiest way to move files from computer to your iPhone without relying on iTunes.
By iMobie | Posted on: Dec. 06, 2018, Last Updated: Dec. 06, 2018
Home > AnyTrans > iPhone Transfer > How to Transfer Files from PC to iPhone without iTunes
To move data from computer to iPhone, most of the users do this using iTunes. However, while transferring files from PC to iPhone with iTunes, existing data on iPhone get erased. That makes people search for an alternative way to iTunes.
Luckily, there is a wonderful alternative to iTunes and it is AnyTrans for iOS that helps users to transfer files from PC to iPhone without iTunes. AnyTrans for iOS is the software that is specially designed for data management on various iOS devices by iMobie. No matter which file type you want to transfer, the software will help you in transferring your desired files with ease. It is the free non-iTunes way that iOS users can try to manage their device data in a smart and efficient way.
 Main Features of AnyTrans for iOS:
AnyTrans for iOS works on both Windows and Mac system. No matter which iPhone model you are using, the software is fully compatible with every iPhone device.
Here, we have mentioned its significant features that you can have.
 How to Transfer Files from PC to iPhone without Using iTunes
Transferring files from PC to iPhone without iTunes has become easier and all thanks go to the software, AnyTrans for iOS. With the help of this software, you can transfer desired or precious files from PC to iPhone without any hassle.
Here is the step-by-step guide on how to transfer files from PC to iPhone without iTunes with the help of AnyTrans for iOS:
Step 1: Download and install AnyTrans for iOS on your PC and then, run it after installing it. After that, connect your iPhone to PC using a digital cable.
Step 2: Now, tap on the “Add Content” button to choose the desired files you like to transfer from your computer to iPhone such as videos, photos and etc.
How to Transfer Files from PC to iPhone without iTunes -Step 2
Step 3: You can also click on the “Category Management” button to select specific file category you want to transfer such as music. So, tap “Audio” and then, choose “Music”.
How to Transfer Files from PC to iPhone without iTunes -Step 3
Step 4: Now, tap on “+” button and select songs from the computer and then, tap on “Open” to begin the transfer process from PC to iPhone.
How to Transfer Files from PC to iPhone without iTunes -Step 4
Thus, AnyTrans for iOS is a great solution in transferring files from PC to iPhone without iTunes. It is a safe and simple tool so must try yourself and get to know how amazing it is for iOS users to manage or transfer files between iPhone and computer without iTunes. Also, share the guide with your friends also to aware them about the most powerful software. Now just get it to your computer and start a free trial >
