How to Recover Deleted Data from iPhone Internal Memory
Accidentally lose contacts, messages, photos or other precious data from your iPhone and urgent to get them back? Don’t worry, this article will show you the details about iPhone internal memory recovery.
By iMobie | Posted on: Jan. 08, 2019, Last Updated: Jan. 08, 2019
It seems almost inevitable that data loss increasingly happens without any warning. The worst situation is that losing data occurs in the blink of an eye thus you even have no chance to make a backup in time. In view of this case, users spare effort to looking for ways of iPhone internal chip recovery. Then, how to perform iPhone memory recovery?
Deleted files are temporally stored on your iPhone’s internal memory when you perform the deletion, but the area is invisible to users. And the files just stay there temporally and can be overwritten by new data any minute. So, with regard to iPhone internal memory recovery, the ultimate solution is to make use of best professional iPhone data recovery. It helps you deeply scan and find all deleted or lost data on your iPhone memory, as long as they’re not been overwritten by newly generated data, they can be found and recover.
How to Recover Data from iPhone Internal Memory
Now, let’s see how to recover deleted/lost data from iPhone internal memory with the aid of iPhone internal memory recovery software. Among multiple choices, here we recommend an award-winning one – PhoneRescue for iOS data recovery. Why PhoneRescue? Because it can enable you to:
Besides recover from iPhone internal memory, two more recovery modes are provided for you: recover from iTunes backup and recover from iCloud backup.
3 Steps to Perform iPhone Internal Memory Recovery
Step 1 Download and run the iPhone internal memory recovery software.
Download and install PhoneRescue for iOS on your computer > Connect your iPhone with USB cable > Click “Recover from iOS Device”.
How to Recover Data from iPhone Internal Memory - Step 1
How to Recover Data from iPhone Internal Memory – Step 1
Step 2 Select the type of data recovery and perform the scanning.
By default, all categories will be selected. Select all or just choose the data type you need. Click OK to start scanning.
How to Recover Data from iPhone Internal Memory - Step 2
How to Recover Data from iPhone Internal Memory – Step 2
Step 3 Preview and recover.
Preview and select the data you want to recover from your iPhone internal memory, then click the Recover button.
How to Recover Data from iPhone Internal Memory - Step 3
How to Recover Data from iPhone Internal Memory – Step 3
Above method of recovering deleted data from iPhone internal memory is the worst case of data loss. However, if you’re lucky enough to make a backup before encountering data loss, then you can still restore lost data from iPhone internal memory from iTunes backup or from iCloud backup.
