If you have got a number of accounts that it has become impossible to memorize the password for each of those accounts, the following posts lists some of the best passwords managers for iPhone and iPad that will save and manage the passwords for you.
If there is one thing that many users do not like on their iPhones, iPads, or any other device, it is inputting your passwords to log-in to your account. For each and every account that you hold, there is a password that you need to enter before you can access the account. Fortunately, nowadays there are so many password managers available that you don’t need to memorize any of your passwords at all.
In the following post, you are going to learn what exactly an iOS password manager is, how you define the best password manager for iOS, and then you have our handpicked passwords managers that you should be using on your iPhones and iPads in 2019.
Let’s check out the post:
A password manager, as the name implies, is an application that manages your passwords for you. Basically, a password manager is where you store your passwords. Then when you need your password, it can retrieve those passwords for you, in no time for most managers.
With a password manager app on your iOS-based device, you no longer need to memorize passwords for your web or any other accounts. The app does that for you and some of these passwords managers even auto-fill the login details for you in your apps and websites.
In a nutshell, a password manager helps you store and retrieve your passwords on your multiple iOS devices.
Now that you know what a password manager is, you may be interested in finding out what makes a password manager the best password manager. There are a number of factors that define an app as the best manager for your passwords and the following are some of the factors for your information.
Since passwords are confidential information, these have to be saved in an encrypted environment or there are security risks. Passwords that are saved in non-encrypted storage can easily be hijacked or stolen. This is the number one factor that each and every best password keeper for iPhone and other devices should have.
A password manager is not much of a use if it cannot auto-fill the passwords for you in your apps and websites. The best password manager must have this feature to make it easier for users to log-in to their accounts.
By now, you know what a password manager is and what makes something the best password manager for your iPhone and iPad. The following are some of the best password managers for your iOS-based devices.
Best Password Manager #1 – LastPass
LastPass is easily the best FREE password manager for your Apple devices. The app lets you store, view, and use passwords on your iOS devices with ease as it has some really great features that make it possible.
The app stores your passwords along with the company’s logos to make it easier to find your passwords. For example, if you are looking for your Google passwords, you only need to find the Google logo which is a pretty easy task and you will have your passwords listed there for it.
Best Password Manager #2 – Dashlane
Dashlane stores your passwords for your chosen accounts and it also lets you know when any of those account platforms have had a data breach. That means if your favorite website has had an attack and users’ data got stolen, the app will notify you so you can take appropriate actions.
The import feature in the app makes it easy for you to import passwords from other apps.
Best Password Manager for iPhone iPad #3 – Keeper
Keeper is a password manager that utilizes Touch ID to let you access the saved passwords on your iPhone or iPad. It has an extra layer of protection as well that ensures no unauthorized users can access your secure data.
Best Password Manager for iPhone #4 – 1Password
1Password has been the choice for the majority of iOS users as it lets you store your passwords as well as your other confidential information including your credit card details. It keeps your data in a secured encrypted environment and lets you pull it anytime you want.
It has support for both Touch ID and Face ID to let you access your encrypted information.
Best Password Manager for iOS #5 – Enpass
Enpass lets you store more than just passwords on your devices. It has a desktop app as well as a Safari extension to let you quickly access your passwords on your other devices. It utilizes various cloud services to keep your data in sync.
It has a modern and user-friendly interface that you will enjoy using on your device.
With our best passwords managers for iPhone and iPad listed above, you should be able to eliminate the need of manually memorizing passwords for your various web and other accounts. We hope it helps you.
