Top & Best Ringtone Maker for iPhone
Looking for best ringtone maker for iPhone? Go through this quick guide as here you will get to know about several ultimate ringtone makers for iPhone you can try.
Joy Taylor Last Updated: Apr. 27, 2020
Apple iPhone comes with limited default ringtones and not everyone is satisfied with default ones.  If you have come to this page then it means you also want to set customize ringtone on your device. Fortunately, you can easily make your own customized ringtone and all thanks go to iPhone ringtone maker tools. They have made so easier for users to have the ringtone of their choice. Here, in this guide, we come up with one of the best ringtone makers, specially designed for iPhone.
  1.    AnyTrans for iOS
When it comes to best ringtone maker for iPhone, AnyTrans for iOS always comes first. This is the software developed by iMobie. With the help of it, you can select the audio file you want to customize from the computer, an iOS device, iTunes library or the internet. The software is available for both Windows and Mac users and moreover, it works with every iPhone model.
Here is the simple step-by-step guide on how to make a customized ringtone using AnyTrans for iOS:
Step 1. To begin the process, just download the software from its official site first and then, install and launch AnyTrans for iOS on your computer. Then, click on “Device Manager” and then, click on “Ringtone Manager”.
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS - Step 1
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS – Step 1
Step 2. Now, you can select the music file from the computer, or iPhone, or iTunes or can search online. So, select the music you want to customize.
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS - Step 2
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS – Step 2
Step 3. Next, you can change the start and end time to make it a text tone. Once all settings are done, click on “Import to Device” button to transfer it to iPhone directly.
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS - Step 3
2018 Top & Best Ringtone Maker for iPhone via AnyTrans for iOS – Step 3
  1.    TunesMate Ringtone Maker
TunesMate Ringtone Maker is developed by iMyFone that help users to customize the ringtone. It supports various formats such as .mp3, wav and many more. You can select the songs from iPhone, or computer. You can select the favorite part of your song to set it as a ringtone. Moreover, the software will automatically convert incompatible formats that will play on iPhone without any trouble. Before transferring to iPhone, you can also preview the ringtone. With TunesMate, you can also transfer ringtone between iPhone and computer without losing any data and quality.
2018 Top & Best Ringtone Maker for iPhone via TunesMate Ringtone Maker
  1.    Wondershare TunesGo
Wondershare TunesGo is the ultimate iPhone ringtone converter which is free to use for users. It is a really wonderful tool that will let you customize song exactly you want. Moreover, you can select a particular part of the song and thus, you can express your creativity in the song you want to customize. This tool is great iPhone manager and it fully supports all iOS version. However, this tool is not easy to use for beginner level users and you need to purchase the software to get its all features.
2018 Top & Best Ringtone Maker for iPhone via Wondershare TunesGo
  1.    Xilisoft iPhone Ringtone Maker
With Xilisoft iPhone ringtone maker, you can create your own ringtone for iPhone from your favorite song or video. The software supports various video and audio format such as MPEG, AVCHD, MOV and many more. With the tool, you can transfer custom ringtone directly to your iPhone. It is fully compatible with the latest iPhone models, such as iPhone XS/XS Max and many more. It also lets you convert audio format, WAV, MP3, etc into M4R format. However, it is complicated to use and sometimes, it fails to save ringtones to iPhone directly.
2018 Top & Best Ringtone Maker for iPhone via Xilisoft iPhone ringtone maker
That’s all on best ringtone maker for iPhone and now, whenever you want to make own customized ringtone, you can use any of above-mentioned ringtone maker. However, AnyTrans for iOS is the most recommended tool as it includes every feature that other tools have. Moreover, it comes with many remarkable features that make this tool all-in-one for managing various iOS devices content on computer.
Joy Taylor
