How to Delete Apps on iOS 13
If you found that deleting apps on iPhone is a little different after iOS 13 updates, you can read this post and realize how to uninstall apps successfully.
Roger Smith Posted on: Sep. 25, 2019, Last Updated: Sep. 25, 2019
Since iOS 13/13.1 were released for some time, they’re already available for public to install. And they’re also ready to accept reviews from Apple users. If you are still hesitating to renew your older iOS version, you may need to know iOS 13 new features or how long does iOS 13 update take.
Once you updated, you will find that iOS 13 changs how to arrange the home screen a little. And deleting apps is a bit different from iOS 12. Here, we’re going to introduce four ways to you about how to uninstall apps on iOS 13 for your iPhone.
iOS 13 Updating Information from iPhone
iOS 13 is compatible with iPod touch (7th generation), iPhone SE, iPhone 6s and later.
How to Delete Apps on iOS 13 from Home Screen
Step 1: Press the icon of the app you want to delete. When the context menu appears, some shortcuts of the app will be displayed.
Step 2: Tap Rearrange Apps, all your apps will shake as before.
Step 3: Click “X” on the top-left corner of the icon and select the Delete button.
Tap Rearrange Apps and Click <span>“X”</span> to Delete the app
Tap Rearrange Apps and Click “X” to Delete the app
Step 4: Tap “Done”(iPhone X and later) or press the Home button (iPhone 8 Plus and before) to finish.
Step 5: Or, you can long-press on the icon, the context menu will appear but ignore it. Just keep pressing and holding for more than three seconds. This will take you directly into jiggle mode and click “X” to delete.
  1. iOS 10 and later enable us to remove some built-in apps. But you should know there are still some default apps that you cannot delete, including Messages, Phone, Settings, Safari, Clock, Camera, Photos, App Store, Health, Wallet and Find iPhone.
  2. If you failed to delete apps, please check whether you Don’t Allow Deleting Apps (for iOS 12 and later). Allow deleting apps: simply go to Settings > Screen Time > Content & privacy restrictions > iTunes & App stores purchases > Deleting Apps > Allow.
How to Remove Apps on iOS 13 from App Store
Step 1: Open App Store.
Step 2: Click the head portrait of your Account.
Step 3: Choose the app you want to delete. Swipe left and tap Delete.
Step 4: Click Done to exit.
Removing apps from App Store is only available for the app updated recently or upcoming updates.
How to Uninstall Apps on iOS 13 from Settings
If you think triggering jiggly mode is inconvenient, there is another option to delete apps from Settings. Please follow the steps:
Step 1: Open Settings and Tap General.
Step 2: Then choose iPhone Storage.
Step 3: Click the app you want to delete.
Step 4: Tap Delete App to confirm that you want to delete it.
1. Besides Delete App, one new feature – Offload App is available from iOS 11, by which the app’s documents and data will be kept. Reinstalling the app will place back your data if the app is still available in the App Store at the moment.
2. If you need to free up storage by the app frequently, you can also apply Auto Offload. Open Settings > iTunes & App Stores > Offload Unused Apps. It will automatically remove apps you don’t use for some time, but also keep all documents and data like Offload App.
How to Delete & Manage Apps on iOS 13 in a New Way
If you want to apply multiple apps deleting action in one click, or you’d like to manage your app and data orderly.  AnyTrans for iOS absolutely can help you. As a comprehensive iPhone data manager, AnyTrans for iOS does a great job in managing iPhone apps, photos, messages, contacts and more.
Here are some of its main features you may be interested in:
  • It can manage your apps effectively, such as delete apps, add apps to iPhone.
  • It supports you transfer app and app data from iPhone to new iPhone (iPhone 11 supported) in one click.
  • Also, you can search and download apps from App Store to App Library, and update or install apps from App Library to device.
  • In addition, with widgets like Home Screen Manager and App File Sharing, you can easily rearrange your apps in some ways and share app files with others.
Now get AnyTrans for iOS and delete apps on iOS 13 for your iPhone:
Step 1: Open AnyTrans for iOS on your computer and connect your iPhone to computer.
Step 2: Click Device Manager and choose Apps category.
Click Device Manager and Choose Apps
Step 3: Select the app you want to delete through the list, or select all.
Step 4: Tap Delete icon on the top-right corner.
Select the App You Want to Delete Through the List
The methods will delete both the apps and their data completely, so please think twice before you remove the apps. Or you can backup the apps with AnyTrans first before you remove them.
As you can see, deleting apps changes a bit from iOS 13. After you read the above methods, hope any one of them can be helpful. If you have other easy ways to delete the apps, please feel free to share your opinions in the comment section. If you meet some problems after iOS 13 updates, you can follow the solutions or just share some with us!
Roger Smith
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
