If you are not sure what differentiates iTunes and Apple Music, the following guide should shed some light on it so you easily understand the differences. Just read on to learn everything about these two great music services.
If you have been in the Apple ecosystem for a while, you would have probably heard the terms Apple Music and iTunes. While both the things are similar to each other in many ways, there are a few things that differentiate them from each other. While one lets you locally manage your music files, the other lets you listen to new music tracks available in the market.
iTunes vs Apple Music
Both have their own set of features that you can enjoy on your various devices. However, it is important that you know what service does what so you can get the one that is suitable for you and your devices. The following guide is all about iTunes and Apple Music and it tells you what the difference is between Apple Music and iTunes so you are in the know.
First off, let’s start with iTunes and find out what features it has for you. iTunes is a program for your computers that allows you to add and manage your multimedia content on your machines. Once you have installed the app on your computer, you are ready to use the app to listen to your music files, create albums and playlists, and even export your music files.
iTunes lets you play music files, movies, videos, and a lot more on your computers. The app interface has all the options you would ever need to manage your multimedia content.
Apple Music, on the other hand, is actually a music streaming service that allows you to stream and listen to various music tracks on your supported devices. It is more of like Spotify where you pay a monthly subscription fee that gives you access to millions of songs to play on your devices. It has both a single and family plan and you can choose what fits you and get access to all the songs you wanted to play while on the go on your device.
You have probably guessed the differences between the two services by now but we would still like to shed a light on the differences and make them very clear to you.
As mentioned above, iTunes is a full multimedia content manager that lets you play and manage music, videos, and many other types of multimedia files whereas Apple Music is only a music streaming service. It does nothing but lets you listen to music on your devices.
iTunes is a media player application that lets you play media whereas Apple Music is a service and it cannot be used as an app to play any kind of media files on your devices.
iTunes lets you organize and manage your content whereas Apple Music does not let you do anything like that.
iTunes lets you purchase media items whereas Apple Music uses a monthly subscription model to provide you access to songs.
iTunes | Apple Music |
It is a media player. | It is only a music streaming service. |
It can be used to manage iOS devices. | It is only used to listen to music. |
It is free to use unless you wish to buy something. | It has a monthly subscription fee attached to it. |
It lets you sync your items. | It does not let you sync anything. |
While iTunes is a great way to exchange files between your iPhone and your computer, it lacks many of the features that make the transfer operation convenient for users. If you do not like the app for any reason, you have some great alternate methods available to transfer music from your computer over to your iPhone.
Meet AnyTrans, an application that lets you transfer content including music from your computer over to your iPhone. The app uses a few clicks approach to let you transfer your files from one device to another in the matter of a few minutes. Some of the features you might be interested in are:
If you would like to give this iTunes alternate method a try, the following is what you need to do.
Step 1 Free Download AnyTrans and install the app on your computer.
Step 2 Connect your iPhone to your computer using a compatible cable, launch the app on your computer, and click on the option that says Add Content in the app.
How to Transfer Music from Computer to iPhone without iTunes – Step 2
Step 3 Select the music files on your computer that you would like to be added to your iPhone. Click on the Open button when you have made your selection.
How to Transfer Music from Computer to iPhone without iTunes – Step 3
The app will start transferring your chosen music files from your computer over to your iPhone. The task should not take too long to finish.
Apple Music vs iTunes is not a battle as they are two different things providing different services to their users. We hope the above guide has provided you with the answers you have been looking for regarding these two services.
