Seek to find your Wi-Fi password? In this guide, we will help you find Wi-Fi password without jailbreak. Now, you can follow this simple guide to learn how to make it.
Is there a way to get my network selection to display my Wi-Fi password which automatically signs on but I have stupidly forgotten?
To ensure the network’s security, many users would like to set a very complex Wi-Fi password with capital letters, numbers, and symbols. Over time, as a result, they can not even remember the Wi-Fi password, just like the user we mentioned above. If you are experiencing the same issue, don’t fret. You can get some useful tips to find your Wi-Fi password on iPhone with or without jailbreaking your device.
In this part, we will provide you with 3 methods to find Wi-Fi password on iPhone without jailbreaking and either of them is easy to conduct. Now, you can follow the step-by-step instruction to do it.
This is the second way that can be used to find Wi-Fi password on iPhone without jailbreaking. If you have logged in the same iCloud account on different iOS devices, then you can use Keychain to sync and view the Keychain passwords between your Apple devices. And notably, this method can only be conducted by a Mac computer.
Here we divide the process into two parts, one is to sync iPhone Wi-Fi password to Mac, the other is to view the password on Mac. Now, you can follow the steps below to view your Wi-Fi password.
How to See Wi-Fi Passwords on iPhone Use iCloud Keychain Sync – Step 2
3. Then, you can double – click on the network, a window that contains information about this network will be presented. Then you can check the box that asks you to show password.
How to See Wi-Fi Passwords on iPhone Use iCloud Keychain Sync – Step 3
4. Type the Administrator’s name and password to allow to use the “System” keychain. After that, you can see your Wi-Fi password.
How to See Wi-Fi Passwords on iPhone Use iCloud Keychain Sync – Step 4
If you don’t have a Mac computer, you can also find wifi password on iPhone without jailbreak. AnyUnlock – iPhone Password Unlocker is right here to help you find WiFi password on iPhone. As one of the most professional iPhone Password Managers in 2022, AnyUnlock can quickly scan the saved passwords on your iPhone. No matter you are using a Windows or Mac computer, you can easily use AnyUnlock to find the specific WiFi password according to your needs.
Now, install AnyUnlock on your computer and take the following instructions to find WiFi password on iPhone without jailbreak.
Step 1. Open AnyUnlock on you computer > Click on the iOS Password Manager feature in the middle bottom of the interface.
Click on iOS Password Manager
Step 2. Connect your iPhone to the computer > Read the notes on the interface and tap on the Scan Now button to proceed.
Click on Scan Now to Scan for Safari Passwords
Step 3. Enter a random password and click on OK. On the left panel, choose the WiFi Account option. Now you will find the saved passwords on your iPhone. You can click on the Export button to get the exact one you like.
View Saved Passwords Listed on Your iPhone
This method is mainly talking about how to view Wi-Fi password on iPhone without jailbreaking through accessing the settings of IP address that locate in Wi-Fi router. It’s easy to perform. Now, you can make it by following the steps.
Step 1. Go to the Settings > WLAN > Tap the Wi-Fi name that you want to find the password > Tap the “i” icon > Copy the address of the Router.
How to Find Wi-Fi Password with Router Settings – Step 1
Step 2. Open your browser and paste the Wi-Fi router that you copy from step 1 to the search box of the browser > You will be presented a login panel page > Log in with the default username and password of your router. Usually, both of the username and password is the “admin”.
If the username and password are incorrect, just tap the “default password of 192.168. XX (your router model) in the Safari to search for its username and password.
How to Find Wi-Fi Password with Router Settings – Step 2
Step 3. After logging in, you will go to the interface of Wireless Setup or Wireless Settings, then you can view the iPhone Wi-Fi password.
This part is mainly talking about how to see Wi-Fi passwords on jailbroken iPhone. In order to see Wi-Fi password on a jailbroken iPhone, you need to ask some Cydia tweaks for help. Here we will introduce 2 popular Cydia tweaks for you to try.
Step 1. Download and install NetworkList from Cydia.
Step 2. Tap “ Restart Springboard” when you are asked.
Step 3. Go to the Settings > Tap WLAN > Known Networks. Then you will see all passwords for the Wi-Fi networks you have connected.
Step 1. Download and install Wi-Fi Passwords on your iPhone.
Step 2. Press the Home button to return to the Home screen. Launch the “Wi-Fi Password” app, then all Wi-Fi networks that you’ve used on the iPhone and their passwords will be shown to you.
Besides the two tools we talked about above, you can also use many other tools like iSpeedTouchpad, Speedssid, Dlssid and more.
That’s all of the methods that we provide for you. Hope you have found the Wi-Fi password on iPhone with the help of AnyUnlock. If you have a better way to find Wi-Fi password on iPhone, just leave your methods in the comment section to share with others.
