How to Fix iOS to Normal on Mac/PC without Losing Data
Tiresome iOS system problems indeed bring a lot of inconvenience for iOS users and make them feel so depressed. Well, thanks to this article which offers 2 practical methods to help you fix iOS to normal.
By iMobie | Posted on: Jan. 15, 2019, Last Updated: Jan. 16, 2019
Every iOS user will encounter various kind of iOS system problems, such as your iDevice get stuck in a black screen or white screen, shows Apple logo, stuck in recovery mode, keeps restarting or looping, etc. Actually, many iOS system problems can be fixed by simply restarting or force restart, however, sometimes a reboot will go useless and you have to look for other ways to fix iOS to normal.
In the following article, we will show you two methods about how to fix iOS to normal. One is the official method offered by Apple but which will lead to current data loss, the other one is making the use of professional iOS system repair tools to fix iOS to normal without data loss. Let’s read on to see how to make it.
Part 1: Fix iOS to Normal by Restoring with iTunes App [Data Loss]
In most cases, most iOS system problems can be solved by restoring your device in iTunes. Such as your iDevice stuck in recovery mode, DFU mode, white or black screen loop, Apple logo etc., you can follow the below steps to get the iOS system fixed. Notice to make a full backup of your device before doing this restore.
Step 1 Ensure that you’ve installed the latest version of iTunes and launch it on your computer.
Step 2 Connect your iPhone or iPad iPod to the computer with its USB cable.
Step 3 Select your iOS device and click Summary.
Step 4 Click the option of “Restore iPhone …” and confirm the action.
How to Fix iOS to Normal by Restoring
Once the restoring process completes, your device will reboot normally, and all your device data will be erased. If you don’t want to lose current data, you can opt for the second method.
Part 2: Fix iOS to Normal without Data Loss
To fix iOS to normal without losing data, you need the help of iOS system recovery tool. With best iOS system recovery software, you can easily get your device out of different iOS trouble without effort. However, how to define the best iOS system recovery and how to select the most reliable one among multiple choices? Don’t worry too much, here is a comprehensive review sums up the top 5 best iOS system recovery software with its pros and cons to give you the detailed reference.
After picking out the one you prefer most, then you can follow this step-by-step tutorial to fix your device system to normal.
To avoid losing data after fixing iOS to normal, please keep in mind to backup your iOS device before doing any repairs on your device. Above ways can help you fix iOS to normal easily and quickly, any better suggestion, let us know in the comment section. Hope you can get your iOS problems fixed as soon as possible.
