How to Fix Unable to Share Message on iPhone Error
If you are unable to share messages on iPhone, the following guide should help you fix the issue and make it possible for you to share iPhone from your iPhone with other iPhone and iOS devices. Read on to find out all the possible fixes to the issue.
Joy Taylor Last Updated: Jun. 04, 2020
Apple ecosystem works so great that you can share almost all kinds of content from one iOS device to another without much hassle. For example, you can share the messages from your iPhone with another iPhone or iPad by just enabling a single option. However, there are times when the sharing feature gets an issue and doesn’t work as it is supposed to. One of the common sharing errors most iOS users get is unable to share messages on iPhone.
If you are facing the issue and are unable to get your iPhone messages on another iPhone no matter what, the following post will offer some solutions to the issue for you. It explains what you can do when the issue occurs so you can fix it and get your messages to show up on all of your iOS devices. Let’s see how to fix unable to share messages on iPhone issue:
How to Fix Unable to Share Message on iPhone Error (Normal Fixes)
In this section, you are going to learn about the solutions that don’t require you to install third-party content on your device. These methods use the built-in options on your iPhone to let you fix the message sharing issue on your device.
Fix 1. Use the Same Apple ID on Both iPhones
The first requirement of message sharing on iOS devices is that all of your devices must be using the same Apple account. If that is not the case with you, you will have issues sharing your messages as Apple cannot recognize it is you on your other iOS device.
It is darn easy to fix this issue as all you need to do is make sure all of your Apple devices are using the same Apple account. If not, you can log-out from the existing accounts on your devices and log back in using your main Apple ID.
Fix 2. Log Out of and Back into Your Apple ID
Sometimes there could be a glitch in your Apple account and toggling the sign-in/sign-out option should fix the issue for you. Basically, what you need to do is sign out of your Apple account on your device and then sign back in after a minute or so.
Open the Settings app > Tap on your name at the top > Scroll down and Tap on “Sign Out” to log-out of your current Apple account on your device > Then, wait for about a minute and then log back in using the same login credentials.
How to Fix Unable to Share Message on iPhone - Use the Same Apple ID on Both iPhones
How to Fix Unable to Share Message on iPhone – Use the Same Apple ID on Both iPhones
Fix 3. Check and Reset Network Settings
Since the message sharing feature utilizes your network connection, it is important that it is active and works. You can check your network settings in the Settings app on your iPhone.
If you find there are issues with your network settings, either you can manually fix the issues or you can simply reset all the settings to the defaults and re-configure them. If you would like to go with the latter option, open the Settings app and tap on General followed by Reset. Tap on Reset Network Settings and it will bring all of your network settings to the factory settings.
How to Fix Unable to Share Message on iPhone - Reset Network Settings
How to Fix Unable to Share Message on iPhone – Reset Network Settings
Fix 4. Restart Your iPhone
If you are still unable to share messages on your iPhone, you may want to try rebooting your iPhone. Sometimes, as simple as rebooting an iPhone does the trick and resolves the issue you are facing on your device.
To reboot your iPhone, press and hold down the Sleep button on your device. Then, drag the slider and it will shut your device down. Then, press and hold the Wake button for a few seconds and your iPhone will boot-up.
Fix 5. Enable iMessage in the Messages App
Messages of your iPhone are usually shared using the iMessage feature and you must make sure it is enabled on your iPhone. It is simple to check the status of the feature and the following is how you do it.
Launch the Settings app on your iPhone > Tap on Messages > On the following screen, ensure the toggle for iMessage is in the ON position.
How to Fix Unable to Share Message on iPhone - Turn on iMessage on your iPhone
How to Fix Unable to Share Message on iPhone – Turn on iMessage on your iPhone
How to Fix Unable to Share Message on iPhone with AnyTrans
If you haven’t been able to fix the issue yet, you may want to use a third-party app to share messages from your iPhone with other devices without much hassle. AnyTrans is such a professional iOS data manager that allows you to share various kinds of content including messages, contacts, photos, music between two iOS devices.
Once you install it on your computer, all you need to do is click on a few options and all of your messages will be transferred from iPhone to another iDevice.
You can also preview your data on iPhone and choose to transfer your files selectively or wholly to another iPhone.
Download AnyTrans on your Mac or PC now and the following is how you can go about doing it:
Step 1. Launch AnyTrans on your computer > Plug-in both of your iPhones to your computer > Click on Phone Switcher from the left panel > Then choose Phone to iPhone.
Choose Phone to iPhone
Step 2. Make sure the order of the iPhones is correct on the following screen and then click on the next icon to move forward with the process.
Select the Source iPhone and the Target iPhone
Step 3. You will be asked what categories you would like to merge with your iPhone > Select Messages > Then click on the next icon to move forward.
Merge Messages from iPhone to iPhone
The app will start merging (transferring) messages from your first iPhone to your second iPhone. Soon as all the messages have been transferred, you will be notified of the same on your screen.
Not being able to share messages on an iPhone is a common issue that most users face and it can easily be fixed as shown in the above guide. For more flexibility and easiness, you are recommended to use AnyTrans to perform the share message operation on your devices.
Joy Taylor
