How to Share iTunes Library
If you have created a library in the iTunes app on your computer, the following guide should teach you how you can share this iTunes library with others on your network. Read on to learn multiple ways of doing the task on your computer.
By | Last Updated: May. 28, 2019
iTunes is an excellent app to add and manage your multimedia content as it has a lot of features that make managing your content much easier than any other app. That is probably the reason why millions of people have chosen iTunes as their primary media management system. In iTunes, users usually create libraries where they manage and keep their content.
Sometimes you may want to share your iTunes library with other users on your network. Maybe you want for them to see your years of hard work that you have put in creating those libraries. Or maybe you just want for them to access the same content that you do on your device. Regardless of the reasoning, the following guide should teach you how to share an iTunes library using a few easy steps on your computer.
How to Share iTunes Library Using Apple’s Home Sharing
Apple’s Home Sharing feature allows you to share items from your computer and you can use it to share your iTunes libraries as well. The feature is pretty easy to use and this section should teach you how you can utilize it for iTunes library sharing.
The first thing you will want to verify is if iTunes sharing is enabled by your firewall on your computer. If you are on Windows, you may not have to do anything as sharing is already enabled on your machine. However, if you use a Mac, you will need to follow the first step as shown below to turn firewall off on your machine.
Step 1 On your Mac, click on the Apple logo at top-left corner and select System Preferences. Click on Security & Privacy, select the Firewall tab, and click on Turn Off Firewall. It will disable the firewall on your Mac.
Share iTunes Library - Disable firewall
Share iTunes Library – Disable firewall
Step 2 Launch the iTunes app on your computer and log-in using the Apple account that you use on your all other devices. Then, click on the File menu at the top and select Home Sharing and click on Turn On Home Sharing.
Enable Home Sharing in iTunes
Step 3 Enter in the password for your Apple account for verification.
Password Verification for Enabling Home Sharing in iTunes
Step 4 Access the iTunes app on any other device of yours on the same network and you should be able to view your shared libraries on the device.
You are all set. You have successfully shared your iTunes library with other users on the same network as long as all the devices use a single Apple ID.
How to Share iTunes Library Using AnyTrans for iOS
When you use Home Sharing to share your libraries, you have a number of restrictions as to how you can share your content. For example, the user at the receiving end needs to use the same app as you to access the content. It is something that not everyone is willing to do to access the content.
Fortunately, though, there is a solution to the issue. It is called AnyTrans for iOS which is an application that lets users share your iTunes content with your iPhone and your computer without the complexity of Home Sharing. In order to share your iTunes content with your iOS device or your computer, all you need to do is select the content you wish to share and it will instantly be transferred to your chosen device.
The following are some of the reasons why you should choose this method instead of the above one for sharing your iTunes library:
  • Do not need to be on the same network to access content.
  • Extremely easy to share your content from iTunes to your iPhone or computer.
  • No need to mess with your firewall settings.
  • Selectively transfer content from iTunes to your chosen device.
  • Fast and secure.
If you would like to try out the application to share your iTunes library, the following is how you do it on your Windows or Mac machine:
Step 1 Free Download AnyTrans for iOS on your computer. Launch the app and plug-in your device to your computer. If you want to share content with your computer, you do not need to connect any device to your machine.
Step 2 Click on “Device Manager” at the top, and then choose the option that says “iTunes Library” to view your library content.
Share iTunes Library Using AnyTrans - Step 2
Share iTunes Library Using AnyTrans – Step 2
Step 3 On the following screen, you will be able to access all the contents of your iTunes library. Choose the files you want to transfer, click on the To Computer or To iPhone button at the top-right corner to share your iTunes library.
Share iTunes Library Using AnyTrans - Step 3
Share iTunes Library Using AnyTrans – Step 3
If you ever need to share your iTunes library or any other content with your iPhone or your computer, the above guide shows how you can do it on your machine without any complex methods. We hope the guide helps you share your content with your chosen devices.
Bella Miller
A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
