How to Turn Off Headphone Safety Notification on iPhone
Are you facing trouble with the headphone safety in your iPhone? If yes, then here is a helpful post for you. In this post, you will learn about how to turn off headphone safety on iPhone. So, continue reading till the end.
Author Avatar Joy Taylor Last Updated: Sep. 28, 2021
If you have purchased an iPhone with the brand new iOS 14 or iOS 15 installed, then you might have already observed that there is a new feature by the name “Headphone Safety” in the sub-menu in Settings. On the basis of where you reside in the world, you may come across some issues with this feature.
With the launch of iOS 14, one of the most prevalent issues is that some Apple users are not able to increase their volume levels beyond a certain point on their devices. If you can’t turn off headphone safety or want to view the details about how to turn off headphone safety on iPhone.
This post will work as a guide for you as here you will read about how to turn off headphone safety on iPhone? But before moving forward, it is important for you to understand the basics of this feature. So, let’s begin!
Also Read: How to Fix iPhone Headphones Not Working >
What is Headphone Safety Feature?
With the release of iOS 14 in 2020, Apple had launched a hearing feature. It was introduced to check the real-time audio decibels levels through a new option available in the control center. The feature was added so as to make sure that headphone audio levels are safe for the health of your ears.
In other words, your iPhone will determine whether you have been listening too loud music over a long period of 7-day. If so, the iPhone will lower the sound levels on its own and will send you a warning notification. Whether you can respond by turning the volume up appears to differ as per your region.
Headphone safety features can be controlled with two buttons: If you enabled Headphone Notifications, your iPhone will measure headphone audio levels, and a notification is sent and the volume is turned down when you exceed the recommend 7-day limit. If you enabled Reduce Loud Sounds, you can limit the volume and reduce any sound.
Although hearing damage and volume control is a serious matter to consider, several users have a counterargument. Some users believe that a private corporation cannot make a decision to listen to music at a lower volume on their behalf. Also, some users have reported that Bluetooth speakers and car stereos are also recognized as headphones by iPhones. Therefore, these devices are also subjected to limitations and warnings.
How to Turn Off Headphone Safety on iPhone 12/11
A description under the “Headphone Safety” heading reads that the feature enables the device to protect your hearings. But with an update in iOS 14.2, you can turn off headphone safety feature. By following the below-listed steps, you should be able to disable the feature:
Step 1: Go to the Settings option on the iPhone.
Step 2: Navigate and select the Sounds & Haptics option.
Step 3: Now, tap on the Headphone Safety option.
Step 4: Disable the Headphone Notifications option. You can also turn off volume limiter on iPhone by disabling Reduce Loud Sounds. Or adjust through the tick ​​mark below.
Turn Off Headphone Safety on iPhone 11
That’s it. In these 4 quick steps, you will be able to solve the issue of how to turn off headphone safety on iPhone.
Turn Off Headphone Safety on Apple Watch
You can also get the notifications – volume should be turned down on your Apple Watch. If you have a need to turn off headphone safety on Apple Watch, just follow the steps below:
  1. Open Settings on Apple Watch
  2. Also, select Sounds and Haptics.
  3. Toggle off Headphone Safety and Reduce Loud Sounds.
That’s all for of how to turn off headphone safety on iPhone. The feature was indeed introduced to safeguard the health of iPhone users. However, it still requires some improvements. But still, you can follow the steps listed above to check and turn off headphone safety on iPhone.
