iOS New Feature – iPhone Data Migration
Apple has introduced a data migration tool with iOS 12.4 and it is quite an interesting feature you can use to easily migrate your data from one iPhone to another. Our guide below covers the feature in detail and offers an alternative as well.
Faye Clarke Last Updated: Apr. 13, 2020
If you have been keeping up with the latest tech news lately, you have likely heard of Apple releasing a newer version of the iOS. The latest version of the operating system now stands at iOS 12.4 and it comes to a brand new feature to help you migrate your iPhone data when you switch phones.
The new feature that has been rolled out with this new iOS update is going to make a lot of users’ lives easier by letting you transfer your content from one iPhone to another in just a few clicks. We take a detailed look at the feature so you know what it does, how it works, and how you can use it on your devices.
What is the iPhone Data Migration Tool in iOS 12.4
The new data migration tool that comes bundled with the iOS 12.4 is nothing but an option added to the initial set up screen you see when you set up your brand new iPhone. The option now makes it easier for you to migrate your data from your old iPhone over to your latest iPhone model.
The tool enables you to wirelessly transfer your chosen data from your old iPhone over to the new one. All it basically requires you to do is place both of your iPhones close to each other, tap an option, and the transfer operation begins.
If you would like to see the operation in action as you wish to perform it on your iPhones, the following shows how you do it.
Step 1. Turn on both of your iPhones and keep them close to each other. Use your Apple ID to log-in to your account on your new iPhone.
Use the iOS 12.4 migration tool to migrate your data
Step 2. A dynamic code will appear on your new iPhone. Scan it using your old iPhone. Then, enter your passcode to continue.
Step 3. Tap on Transfer from iPhone on your new iPhone to begin transferring your content.
Switching Data between Two iPhone
You should be able to select the content that is to be transferred over to your new iPhone. And that is how you use the iPhone migration tool in the latest version of the iOS on your iPhones.
Migrate iOS Data with Ease Using AnyTrans for iOS
Apple’s new migration tool works like a charm to help you easily migrate from one iOS device to another, however, it comes with strings attached to it.
  • First, the feature only works when you are setting up your new iPhone. If you want to transfer content to an iPhone that is already set up, you cannot use the migration tool to do it.
  • Second, the feature only lets you transfer a limited number of file types from one device to another. It does not provide you with the flexibility to transfer the content you want.
If these limitations are holding you back from using the newly introduced migration tool, you have a really great alternative app available at your disposal. This app is called AnyTrans for iOS and it allows you to move data from one iPhone to another without any restrictions.
You do not necessarily need to be setting up your new iPhone to be able to transfer your content. Your content can be transferred at any point in time regardless of the situation with your iPhones. All that the app asks you to do is choose the content you want to transfer and you are all set.
The following shows how you migrate your data from one iPhone to another using the aforementioned app:
Step 1. Download and install the AnyTrans for iOS app on your computer. Plug-in both of your iPhones to your computer using USB cables.
Step 2. When the main screen appears, click on the Phone Switcher and choose Phone to iPhone to transfer content between your devices.
Choose Phone to iPhone on AnyTans
Step 3. Confirm the source device and target device on the following screen. Then, click on the Next icon to continue.
Confirm Source Device and Target Device
Step 4. Select the categories you want to transfer. AnyTrans also gives the option of skip duplicates. Then click the Next to start transferring.
Choose the Categories You Want and Click Next to Continue
Step 5. Wait while the app migrates data from your old iPhone over to your new iPhone.
That’s all there is to it. Your chosen files have been successfully migrated to your new iPhone.
iOS 12.4 data migration tool is a boon for those of you who are looking to switch to a newer model of the iPhone. The tool will let you transfer your content from your old iPhone to the new iPhone in a few easy taps. And if you do not like it for its restrictions, you have AnyTrans for iOS as an alternative.
Faye Clarke
Member of iMobie_Inc, an enthusiastic fan of Apple and Jazz music, always ready to offer advice and solutions to any iOS & Android related issues.
