If you have saved passwords on your iPhone or iPad, the following guide will teach you how you can go about viewing these saved passwords on your iOS devices. Read on to learn how to do it.
In order to make it easier for users to access your accounts, Apple has added the ability to store your account passwords on your iPhone and iPad. Once you have stored a password, you can use it the next time you log-in to the website where you have your account. It eliminates the need of manually entering the password each time you want to log-in to an account in an app or on a website.
Sometimes you may just want to view the saved passwords on your iPhone and iPad. Apple allows you to do it and you can access and view your passwords like regular text on your iOS-based devices. The following are the instructions on how you can go about doing it on your devices.
The feature that saves the passwords on your iPhone and iPad is called Keychain. It works across your Apple devices including your Mac and lets you store, view, and use passwords where and when needed.
If your passwords are saved in Keychain and you would like to view them, the following is how to see saved passwords on your iPhone and iPad.
Step 1 Tap on the Settings app on your springboard to launch the settings panel for your device. That is where your stored Keychain passwords are located.
Step 2 When the settings panel launches, find and tap on the option that says Accounts & Passwords. Your passwords should be in there.
Step 3 On the following screen, tap on the option that says App & Website Passwords to view your saved password in Keychain.
View App and Website Passwords in Keychain on iPhone/iPad
On the screen that follows, you will find all the passwords that are saved in the Keychain for your iPhone and iPad. You can browse your passwords in the alphabetical order or you can use the search feature to search for a specific password.
That is how you view saved passwords on an iPhone and iPad.
If you wish to view the passwords saved in Safari on your iOS device, it is pretty easy to do that as well. Safari passwords are also saved in the Settings app on your iPhone and iPad and the following shows how you can access these passwords on your device.
Step 1 Launch the Settings app from the springboard of your device.
Step 2 When the app launches, find and tap on the option that says Safari. It will open the Safari settings panel for you.
Launch Safari Settings on Your iPhone/iPad
Step 3 When the panel opens, tap on the option that says Passwords. That is where your passwords are stored.
Access the Passwords Section in Safari Settings on Your iPhone/iPad
Step 4 You will be asked to verify yourself using either a passcode or your Touch ID. Do so and it will let you move forward.
Authenticate Yourself Using Your Preferred Method
The following screen will have all the passwords you saved in Safari on your iPhone and iPad. You can use the search feature if you are having trouble finding the password you need.
That is how you view saved passwords in Safari on your iPhone and iPad.
If you ever need to view your passwords that you have saved in either Keychain, Safari, or both, our guide above should help you do it using the most efficient way available. We hope you find the password you are looking for using the above methods on your iPhone or iPad.
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
Users Served
