Have you locked your iPhone, forgot the passcode now, don’t know how to unlock any iPhone without passcode? This article will guide to unlock an iPhone without passcode or Face ID.
Apple allows you to lock your iPhone via multiple ways, i.e., Passcode, Touch ID, Face ID, etc. Many people use passcode and forgot it after some time, and try to use Touch ID or Face ID. But the trouble arises when your iPhone is unable to recognize your Touch or Face ID. Then, you are avail with only one option which is to factory reset your iPhone, but as you know factory reset removes all the data stored on your iPhone.
If you have locked your iPhone and don’t know any way to unlock your iPhone so don’t worry. There are many ways to get into a locked iPhone. Here, we will illustrate you to how to unlock any iPhone without passcode, Touch ID or Face ID using various ways.
Yes! You can unlock a locked iPhone without passcode or Face ID. There are several ways of unlocking an iPhone if you forgot your passcode. You can simply unlock a locked iPhone in just a few clicks.
Here, we will elaborate you how you can unlock an iPhone without the passcode. Stay with us till the end to get to know how to unlock any iPhone without passcode or Face ID.
If you have locked your iPhone and now you are unable to remember the passcode, you must try unlocking your iPhone using a third-party app: AnyUnlock – iPhone Password Unlocker in a rapid and simple manner. Here are the features of AnyUnlock.
Now download and install AnyUnlock on your computer. Then follow the below-given steps to know how to unlock any iPhone using AnyUnlock.
Step 1: Run AnyUnlock on your computer. Use a USB cable to connect your iPhone to the computer. Click on Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2: Click on Start button. Then tap on Download to start downloading the appropriate iOS firmware according to the device.
Click Start Button
Step 3: After downloading the firmware, click on Unlock Now button to start unlocking your iPhone. Wait until the process completes.
Tap on Unlock Now to Continue
Step 4: Once, the process will complete, click on Done to go back to the main interface. Your iPhone will be unlocked.
iOS Device Unlocked Successfully
If you have locked your iPhone and forgot your passcode then unlocking your iPhone via iTunes is one of the best ways of doing so. Using iTunes, you can easily know how to unlock any iPhone in just a few clicks.
Unlock Any iPhone via iTunes
Step 1: Download and Install iTunes or if you have previously installed it, upgrade it to the latest version. Run the app on your computer. Connect your iPhone to the computer via a USB cable.
Step 2: As soon as the iTunes interface opens, from the top left corner click on the device icon. After that, choose ‘Summary’ and then click on ‘Restore iPhone’. Click on ‘Restore’ button to start the restoring process.
Step 3: While updating the newest iOS, iTunes would erase your device and restore your iPhone to factory default settings. All you have to do now is reboot the iPhone and set it up as a new device.
iCloud provides you with many features but one of the finest features of iCloud is Find My iPhone. Find My iPhone allows you to erase your iPhone and unlock it from the list, whether you remember the passcode or not. However, make sure Find My iPhone is enabled on your iPhone, because else this method will fail.
Unlock Any iPhone via iCloud
These steps will help you to how to unlock any iPhone using iCloud.
Step 1: On your computer, open iCloud and visit https://www.icloud.com/find.
Step 2: Tap on ‘All Devices’ option at the top.
Step 3: Select your device which is linked to your Apple account.
Step 4: Choose your iPhone from the drop-down menu, then Erase from the iCloud screen.
If you want to unlock your phone without using Apple ID or even a computer, then this is the easiest way how to unlock any iPhone. You can unlock your iPhone using Siri without any data loss.
Unlock Any iPhone via Siri
Step 1: Click on the Home Button and hold it to active Siri on your locked iPhone.
Step 2: Ask some common questions, like, ‘What is the time?’ and let Siri display the local time on Window.
Step 3: Try sending a new message by clicking on the ‘Share’ and ‘Messages’ buttons.
Step 4: There is no need for you to write anything. Instead, after adding a new contact, you may upload images. When you add images to your iPhone, you’ll be able to access, browse, and select photos from your device’s library.
Step 5: To return to the home screen, tap the ‘home’ or ‘Return’ button after accessing the library. It will automatically unlock your iPhone without passcode or the need for a computer.
If you have activated voice control unlock on your iPhone, you can unlock your iPhone just by saying the phrase you have already approved.
There are two methods how to unlock any iPhone via voice control which we are discussing here,
Method 1: The passcode screen may be accessed by pressing the Home button twice. Afterwards, utter the Voice Control command phrase that you created. Your iPhone will automatically enter the password for you.
Method 2: Take your iPhone, say ‘Hey Sir’ or utilize Raise to Wake to illuminate the iPhone screen. Siri will simply vanish from the home screen after several seconds. Say ‘Go Home’ to go to the password screen, and Voice Control will drive you there. Now, say the Voice Control command phrase that you created.
Locking an iPhone and forgetting the passcode can really make your day tough. Here, we have discussed many ways how to unlock any iPhone without passcode or Face ID. We recommend you to use AnyUnlock as it is the best and simplest way of unlocking an iPhone in just a few clicks. Just download AnyUnlock and give it a try!
