How to See Old Kik Messages on iPhone/Android
If you are missing some of your messages in the Kik app on your smartphone, the following guide should teach you how you can find your old Kik messages on your Android and iPhone smartphones. Read on to learn how.
Joy Taylor Last Updated: Apr. 08, 2020
If you search for instant messaging apps on any of the app store, you will come across dozens of apps that let you send and receive instant messages on your devices. One of these apps is Kik that works pretty much like any other messaging app but it has its own unique features. What makes Kik stand out of the crowd is its feature that automatically does something to help you save your precious memory space on your device.
If you have been using the Kik messenger for a while, you would have found that some of your messages go missing after days of receiving or sending them. This has been the case with all the users of this app and there is a reason why it happens. The following guide uncovers all the mystery for you and tells you how you can see your old Kik messages on your iPhone and Android devices. Without further ado, let’s get onto the mission to find your missing messages in the Kik app.
If you really need access to your deleted Kik messages but you are not sure how to do it, this section will teach you how you can get your old Kik messages back on your iPhone. Enter AnyTrans for iOS, an application that allows you to extract and view even the deleted Kik messages on your iOS-based device such as your iPhone. It does so by first fully scanning your device for any recoverable messages and then offers you the option to either view or transfer Kik messages to your computer.
The following are some of the reasons why people consider using AnyTrans for iOS to view old Kik messages:
  1. View individual Kik messages on your iPhone.
  2. Transfer all the Kik messages from iPhone to computer.
  3. Selectively transfer Kik messages from iPhone to computer.
  4. Safe and secure way to extract your messages.
  5. Modern and extremely easy to use app.
How to See Old Kik Messages on Android
If you have exceeded your Kik messages limit and you are now unable to find your old messages on your Android device, this section will help you get access to your old Kik messages. While there may be other ways of gaining access to your old messages, the fastest and the most straightforward way to view your old Kik messages is to use the AnyTrans for Android.
The app contains the category of the specific message where you can view and transfer all or some of your Kik messages to your computer or another device. It comes preloaded with tons of features to help you find your old Kik messages, and the following are some of the reasons why you should consider using the app on your Android.
  • Preview the messages before you restore them on your device.
  • Selectively restore old Kik messages.
  • Get rid of the ones you do not want to restore.
  • Move messages to either device or computer.
  • User-friendly interface.
To offer more powerful features on Kik management, our development team is working both day and night. More exciting will come soon, let’s look forward to it together.
If you were looking for an answer to your how to view old Kik messages question, the above guide should answer your question and provide you with two amazing apps to help you view all of your old Kik messages on your devices.
Joy Taylor
