Using the best software available to backup and transfer your important data is always a good practice, regardless of which task you are trying to accomplish. BackupTrans is probably one of the first options to look into, but it’s definitely not the only tool you can use for transfer files across different devices and regularly backup your phone. Here is a detailed overview of the possible replacements.
The mobile software industry is extremely competitive, so there are several BackupTrans alternatives that rival it in terms of features, usability, and speed. With that in mind, users who need to frequently transfer photos, videos, text documents, and other media between their primary phone and another device definitely want to have the best tool they can possibly get.
As it turns out, there are multiple software products that deserve your attention, and it’s prudent to analyze them in detail in order to identify which one should be considered the most suitable.
In this sense, it’s worth considering several different aspects of service such as technical quality, the range of supported options, and the quality of user experience, before deciding which alternative is truly the best.
As of 2021, there are two notable software suites that can effectively replace BackupTrans as your go-to backup and file transfer solution. Both have some unique features and advantages, and both are very similar to BackupTrans in terms of functionalities and compatibility with various platforms. Here is everything you need to know about AnyTrans and PhoneTrans before you choose which one to download:
AnyTrans is an extremely reliable personal data management tool designed specifically for mobile phones, and it’s available for both Android and iPhone. In fact, it’s one of the most commonly used programs for transferring WhatsApp conversations and other mobile data between iPhone and Android without effort.
Download AnyTrans on your computer > Connect your Android and iPhone to the computer via USB cables > Click on the “Social Messages Manager” mode. Then click on WhatsApp to Device > Then tap on the “Transfer Now” option to go on.
Choose WhatsApp to Device
For more details, you can also refer to the guide page for transferring WhatsApp from Android to iPhone >
What’s more, one of the reasons for its popularity is its simplicity, but it also offers top-notch transfer speed and amazing flexibility working with countless different data formats and data environments. The app has a specialized mode for backup that takes the user through the process, and can conveniently save all of the user’s private data on a daily basis with just one click.
PhoneTrans is certainly one of the best-known BackupTrans alternatives that is worthy of serious consideration. Its support for a broad range of diverse devices and the ability to work well under iOS or Android makes it a popular choice as a solution for all mobile data transfer needs.
Moreover, PhoneTrans is well suited to keep your social media data safe, and it can effectively transfer and manage conversations and multimedia contents shared through WhatsApp and other messaging apps.
Choose WhatsApp and Start to Transfer
Some of the advanced features that set PhoneTrans aside from any competitors include the ability to automatically reinstall all applications with all data when you switch phones, as well as the capacity to merge data from multiple devices.
PhoneTrans can also be used for backup purposes and to send data from WhatsApp to the cloud on a regular basis. With a simple and intuitive interface and excellent data recovery capacities, PhoneTrans can provide users with complete peace of mind.
Further Reading: How to Restore WhatsApp Messages from iCloud >
Both of the products presented above come with a full slate of practical features that complement the native tools provided by mobile OS.
In terms of phone migration, AnyTrans and PhoneTrans deploy slightly different but equally effective approaches, with automated tools that allow for the transfer of personal data and even entire apps with minimal need for user action.
Since both of those software suites are free to download, it may be best to try them both firsthand and see how well they fit your personal needs.
While native data management apps can struggle with certain cross-platform transfer tasks, there are excellent third-party products that can fill this gap. AnyTrans and PhoneTrans are two of the currently best regarded BackupTransfer alternatives that may be used to handle all types of data transfers with astonishing ease. With one of those apps, you will never again lose a single WhatsApp message, no matter how many times you change phones. Why not download it and have a try?
