If you happen to switch from Samsung to iPhone, you may need to transfer WhatsApp between Samsung and iPhone. In this post, you can find out 3 possible methods to have your WhatsAPP messages moved.
In recent days, more and more Android and iOS users are using WhatsApp to send instant messages, photos, and files. As an effective messaging app, WhatsApp makes it easy to send and receive messages and media. Therefore, when you plan to switch your mobile phone, you may seek to transfer WhatsApp from Android phone to iPhone or transfer WhatsApp from iPhone to an Android device. This post mainly talks about how to transfer WhatsApp from Samsung to iPhone. If you used to use a Samsung device and need to transfer WhatsApp from Samsung to iPhone now, you can refer to this guide to find out 3 efficient ways to make it.
Transfer WhatsApp from Samsung to iPhone
Unlike transferring WhatsApp from Samsung to Samsung, you cannot use Google Drive to transfer WhatsApp from Samsung to iPhone even if you can run Google Drive on either iOS or Samsung device.
Then you may ask how do I transfer WhatsApp from Samsung to iPhone? Luckily, you can still use other tools to get it transferred. Keep reading the post and figure out the most efficient way according to your needs.
Due to the differences of iOS and Android operating systems, you are now allowed to back up Android WhatsApp data and then restore WhatsApp to iPhone. When it comes to transferring data from Android to iPhone, you are highly recommended to use PhoneTrans. As a professional phone-to-phone transfer tool, PhoneTrans has established a special App Transfer mode to help you transfer WhatsApp, Line chats, and Viber messages from one phone to another.
Now, freely download the latest version of PhoneTrans to your computer and take the following steps to transfer WhatsApp from Samsung to iPhone.
Step 1.Open PhoneTrans on your computer > Choose App Transfer > Click on WhatsApp > Tap the Start Transfer button.
Choose WhatsApp and Start to Transfer
Step 2. Connect both your Samsung and iPhone to the computer via USB cables or the same Wi-Fi network. Click on the Transfer button while they are detected successfully.
Choose Android as Source Device and iPhone as Target Device
Follow the instructions on the screen: Back up Samsung WhatsApp data > Install WhatsApp enhanced version > Restore WhatsApp backups to your enhanced WhatsApp.
Step 3. Wait for a few minutes to transfer WhatsApp data from Samsung to iPhone.
Start WhatsApp Transferring Process
If you merely want to view your WhatsApp chats on iPhone instead of opening them on the WhatsApp application, you can export your WhatsApp messages as a .txt document via email:
Transfer WhatsApp Using Email
AnyTrans is another effective tool that can help you to transfer WhatsApp from Samsung to iPhone. As a professional transfer and backup tool, AnyTrans enables you to transfer WhatsApp from an Android phone to an iOS device.
Now, try on the latest version of AnyTrans and take a look at how to back up Samsung WhatsApp messages and restore them to your iPhone:
Step 1. Launch AnyTrans on your computer > Choose Social Messages Manager > Tap the WhatsApp to Device mode.
Choose WhatsApp to Device
Step 2. Connect both your Samsung and iPhone to the computer.
Confirm the Source Phone and the Target iPhone
Step 3. Follow the pop-up steps to back up WhatsApp data on your Samsung device.
Backup WhatsApp on Samsung Phone
Step 4. Log in to your WhatsApp on your Samsung phone and click Restore to restore the backup to the enhanced version of WhatsApp.
Click Next to Restore WhatsApp to iPhone
Step 5. AnyTrans will transfer your WhatsApp data to your iPhone.
Restore WhatsApp to iPhone Now
For more detailed instructions, you can go to the guide page for transferring WhatsApp from Android to iPhone.
As you can see, it is almost impossible to transfer WhatsApp chats from Samsung to iPhone directly and officially. However, you can also use another tool to get them transferred. Now, it’s the best time to download PhoneTrans or install AnyTrans to get your WhatsApp messages transferred across different operating systems.
