How to Change Display Settings on Your Mac
How to change display settings on Mac? Read on this guide to know how to make it on your Mac.
Aug. 13, 2015
MacClean – Clean Your Mac to Free up Space
MacClean – Best Mac Cleaning Software
After reading this guide about how to adjust display settings on Mac, don't forget to download this Mac cleaning tool to cleanup and speed up your Mac to make it work better.
Display resolution determines the size of text and objects on screen. If you don't like the default display on your Mac, you can set the resolution to make text and objects appear larger or smaller to makes text looks clearly or get more space on the screen. Next, we will offer you a step-by-step guide to show you how to change display settings on iMac, MacBook, Mac Mini or Mac Pro.
Can't Miss: How to Free Up Memory on Your Mac >
How to Adjust the Resolution of Your Mac's Built-in Display
Step 1. Open System Preferences > Display > Scaled.
Step 2. To make text larger, click on one of the boxes to the left of Default. On the contrary, if you want to make the text smaller, click on one of the boxes to the right of Default.
Image Credit: imore.com
How to Adjust the Resolution of Your Mac's External Display
Step 2. To make text larger, select a smaller number for the resolution. On the contrary, you need to select a larger number.
If you want to increase or decrease the font size in apps, hold down the Command key and press "+" or "-". To optimize your Mac, you can use a professional cleaning software named MacClean to help you make it in minutes.
