A Full Guide to Fix iPhone/iPad AirPlay Not Working
AirPlay not working? Do as the following instructions to troubleshoot your AirPlay problems. Different situations and relevant solutions are introduced in the post in detail.
By iMobie | Posted: May. 08, 2018, Last Updated: May. 08, 2018
Home > AnyTrans for iOS > AirPlay Problem > How to Fix iPhone/iPad AirPlay Not Working
AirPlay is made by Apple to share video, photos, or the entire screen on your iPhone, iPad or iPod touch to an Apple TV. With AirPlay, you can share iPhone or iPad content directly from an app, or mirror your device’s screen to Apple TV. However, sometimes AirPlay is not working? The post lists all possible situations and the solutions to fix them. Now check for further details.
How to Fix iPhone/iPad AirPlay Not Working Problem
AirPlay only works when you plan to share content to an Apple TV or AirPlay-enabled speaker or receiver, so check if your device is compatible. Meanwhile, make sure you have updated the software on iOS device and Apple TV to the latest version. Then please head to the detailed guide.
Situation 1: No AirPlay Options Are Available
When an AirPlay-enabled device is available, you should see AirPlay options in Control Center on your iPhone or iPad. But if there is no Airplay option available or a “Looking for Apple TV” Message Showing, follow the steps below.
  1. Restart your iPhone/iPad and Apple TV.
  2. On iPhone or iPad, go to Settings > Wi-Fi and check that you’re on the same Wi-Fi network as your Apple TV. To check the Wi-Fi network on your Apple TV, go to Settings > Network > Wi-Fi.
  3. On your Apple TV, make sure that AirPlay is turned on in Settings > AirPlay.
Situation 2: The AirPlay Device That You Need Is Not Showing
Basically, you should do the same thing as situation one when you can’t see the Airplay device that you need.
  1. Make sure that you plug in and turn on the AirPlay device that you want to stream to.
  2. If you’re streaming to Apple TV, make sure AirPlay is turned on in Settings > AirPlay.
  3. On iPhone or iPad, go to Settings > Wi-Fi and check that you’re on the same Wi-Fi network as your Apple TV. To check the Wi-Fi network on your Apple TV, go to Settings > Network > Wi-Fi.
Situation 3: iTunes Store or Third-party Content Can’t Be Streamed
  1. To stream iTunes Store content and some other types of content, your Apple TV needs a stable Internet connection. Go to Settings > Network > Wi-Fi and check your Wi-Fi connection and try again.
  2. To AirPlay rented content, wait for it to download completely. You can’t AirPlay rental content until it fully downloads.
  3. For the app you’re using, check its product page or website to see whether the app supports AirPlay. Without support for AirPlay video playback, an app might not be able to stream video.
Situation 4: No Sound Can’t Be Heard When Watching Video on Apple TV
  1. On both of your iPhone/iPad and Apple TV, check if the volume is turned up and remains not muted.
  2. On your iPhone or iPad, check the Ring/Silent switch. If it’s set to silent, you’ll see an orange line. Toggle the switch to turn on the ringer.
Situation 5: Network Lags or Content Gets Interrupted
If you have a weak Wi-Fi signal or interference from a nearby device, like a microwave or baby monitor, follow these steps below.
  1. Make sure that you use the recommended settings for your Wi-Fi router.
  2. Move or turn off other devices that might cause interference.
Bonus Tip to Transfer Files from iPhone/iPad to Computer
That’s all for the iPhone or iPad AirPlay troubleshooting. If you want to view iPhone/iPad content on computer, an excellent iTunes alternative – AnyTrans for iOS is highly recommended, which enables you to transfer files from iPhone/iPad to computer selectively. Also, it supports moving all content to computer for a local backup. Now just free download it to have a trial >
How to Transfer Files from iPhone/iPad to Computer
Hope the guide can help you fix your iPhone or iPad AirPlay problems. For any doubt, welcome to let us know in the comments below. And if you are interested in the powerful but easy-to-use AnyTran for iOS, get it free downloaded to explore more >
AnyTrans® for iOS
  • * 100% Clean & Safe
11,452,517
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
