How to Fix Android 7.0 Nougat Bluetooth Problems
If you happen to run into the Bluetooth problems on Android 7.0 phones or tablets, you are on the right page. Read to get how to fix Android 7.0 Nougat Bluetooth problems.
By iMobie | Posted: Apr. 08, 2018, Last Updated: Apr. 18, 2018
Home > AnyTrans for Android > Android 7.0 Bluetooth Issue > How to Fix Android Nougat Bluetooth Problems
Although the Android 8.0 Oreo has come to the public, there are a large number of Android 7.0 users still. Android Nougat is the seventh major version of the operating system for Android phones and tablets, which is definitely a sweet update. The long-waited multi-window view, battery saver and seamless update are brought to Android 7.0. And the Custom Quick Settings enables you to get to what you want faster, Bluetooth is included.
Just in case that you meet any possible Bluetooth problems on Android 7.0 and above, the post here will share some reliable solutions to fix the Android 7.0 Nougat Bluetooth issue.
Common Bluetooth Problems on Android 7.0 Nougat
Solution 1. Check If Wi-Fi Is Turned On
Bluetooth and Wi-Fi shouldn’t be turned on at the same time. Make sure Bluetooth and Wi-Fi are off, if not, turn them off. Then turn on only Bluetooth and pair it with your Bluetooth device to see if it works alright.
Solution 2. Change the Pairing Code
When you are connecting with cars or older Bluetooth devices, you need to input the pairing key. Fill in the passkey “0000”, and it should work.
Solution 3. Disable Battery Optimization
The Doze mode on Android 7.0 Nougat makes your device go into low power usage to save battery, which might cause the Bluetooth problems.
Step 1 On Android device, go to Settings > Battery.
Step 2 Tap the three-dot menu at top right and choose Battery optimization.
Step 3 Select All apps option from the dropdown menu.
Step 4 Tap on each of the Bluetooth services (Bluetooth MIDI service, Blocked Numbers Storage, etc.) and apps (Play Music, App music, Phone (calls), music player app of yours, etc.) and select the Don’t optimize option.
Solution 4. Reset Network Settings
This will reset all the setting related to Wi-Fi, Bluetooth and mobile data. Make sure have a note of all this information.
Step 1 On your Android device, open the Settings app.
Step 2 Find and tap on the Backup & reset option.
Step 3 Hit Network settings reset.
Step 4 Tap Reset settings and confirm.
Hopefully, the above tips can help you solve the Bluetooth problems on Android 7.0 Nougat phones or tablets. We before used Bluetooth to transfer a handful of files like songs or pictures from Android to Android. Here a powerful Android files transfer tool called AnyTrans for iOS is introduced to help you transfer files between Android devices in a new smarter way.
How to Transfer Files from Android to Android
Hope the above solutions for Android 7.0 Nougat Bluetooth problem work for you. If you have any other useful ways to fix the issue, welcome to share them with us in the comments below. And for details about AnyTrans for iOS, head to explore more >
AnyTrans® for Android
The best tool to transfer, back up and manage your Android data: to computer, to another Android device, add from computer.
  • * 100% Clean & Safe
