5 Best Battery Saver Apps for Android Device
Found your Android battery drains fast and want some android battery saver apps? Here we collected 6 best battery saver apps for Android.
Joy Taylor Last Updated: Mar. 19, 2020
Recent years, Android smartphones have richened our life with their advanced technology and interesting features, for example, we always rely on smartphones to contacts with friends, browse web pages, listen to music, watch videos, play games and etc. All these activities have brought great pleasure to us and made smartphones an indispensable part of our life.
At the same time, there are a great number of Android phone users reporting that the Android battery drain quite fast as time goes by. You may have tried some common tips like turning the screen brightness down, turning off data syncing or closing some background apps. Actually, you can also try some battery saver apps for Android to improve the battery life on your Android devices.
Also Read: How to Fix YouTube Videos not Playing on Android >
1. Best Battery Saver Apps for Android – Greenify
Developed as a professional battery saver app for Android, Greenify has helped millions of users improve battery life on their Android devices. It stops apps from running on the background and prevents them from launching again until you start them again. It works well on both root and non-root device, and there are two versions of Greenify app. Different from other similar apps’ “close everything” feature, Greenify allows users to choose the list of apps you’d like to close, and everything else stays running.
Best Battery Saver Apps for Android - Greenify
2. Best Battery Saver Apps for Android – Battery Doctor
Battery Doctor is a free battery monitor and energy saving tool for mobile devices, which supports 28 languages and works well on both Android and iOS devices. It allows you to monitor the battery condition according to the app type, and you can optimize battery power with just a tap of a finger. For example, you can set your Android phone to automatically set the airplane mode when you are asleep or on work.
Best Battery Saver Apps for Android - Battery Doctor
3. Best Battery Saver Apps for Android – DU Battery Saver
DU battery save is a free battery saving app designed for Android devices, which has a convenient control widget and one-touch power optimization. The “task killer” widget can help you optimize the battery usage by managing the Wi-Fi, brightness, sound, and data with one-tap. And the Pro upgrade has more great features like supports schedule the power-saving presets to automatically kill the apps on your background.
4. Best Battery Saver Apps for Android – Avast Battery Saver
Avast Battery Saver is a popular battery saver app among Android users, which extends your battery life by stopping apps that you aren’t using and optimizing your device settings. The smart technology intelligently calculates and displays the remaining battery life and prompts you to regulate the actions of those apps and services. Sometimes it can squeeze up to 20% more life from your battery by quitting the apps running in the background.
5. Best Battery Saver Apps for Android – Battery Optimizer & Cleaner
This app offers more features besides batter saver, so you can clean the memory, monitor your mobile battery usage and speed up your Android device. Like internal storage, this battery saving app scans the external storage and detects the blurred pictures and duplicate photos for further space enhancement. It will be a great helper to improve your battery life on Android.
With these apps we offered above, your Android batter life may last for a longer time than before. And if you want to transfer some Android files to computer as a local backup as well as free up space on your device, AnyTrans for Android is helpful for you. Just get it to your computer and have a free trial >
Joy Taylor
Member of iMobie team as well as an Apple fan, love to help more users solve various types of iPhone related issues.
