How to Recover Android Data after Factory Reset
Looking for a reliable and efficient way to recover lost data from Android after factory reset? This guide will show you how to recover data after factory reset from Android with a step-by-step tutorial.
By iMobie | Posted: Dec. 07, 2017, Last Updated: Feb. 27, 2018
Home > PhoneRescue > #1 Android Data Recovery Tool > How to Recover Data from Android after Factory Reset
Factory reset is often an effective method for users to fix some system errors, sluggish device and wipe personal information when people plan to sell their smartphone. When you perform factory reset on your device, whatever data is stored in its internal storage will be erased completely. So, remember to back up your data before committing factory reset.
However, sometimes you may accidently press the factory reset and lose your important files without any backup files. When the situation happens to you unexpectedly, how can you retrieve the lost files can be the hardest tasks. Don’t worry. Here in this guide, we will tell you a simple & quick solution to help you recover the lost files in minutes.
Don’t Miss: How to Recover Deleted WhatsApp Messages on Android >
The Tool You Need for Android Data Recovery after Factory Reset
Here we would like to share you this professional iOS & Android data recovery tool – PhoneRescue to finish the job with no hassle. PhoneRescue for Android is highly recommended by lots of Android users for data recovery after factory reset. And below are the reasons why.
1. It can help you successfully recover all lost files from your Android phone after factory reset, such as photos, videos, music, contacts, messages, Line Messages, call logs and more contents. Just takes a few minutes to finish the job.
2. It also enables you to preview and select the lost files before recovering, which makes it possible for you to recover the data you want.
3. It works well on almost all Android models, such as Samsung, Huawei, Sony, Motorola, HTC, Samsung Tab and more smartphone and tablets.
So, just go to the download page of PhoneRescue and click PhoneRescue for Android to download it on your Mac/PC. Then follow the detailed steps below to recover your lost data from Android right now.
As the software can only access the rooted Android device, you need to make sure that your Android phone has been rooted before recovery. Or you can follow the tutorial shows to you in the page after you check the data categories.
Step 1 Launch PhoneRescue for Android on your Mac/PC computer > Connect your Android phone to the computer via its USB cable.
How to Recover Data from Android after Factory Reset – Step 1
Step 2 Check the data categories you want to recover > Tap Next button on the right.
How to Recover Data from Android after Factory Reset – Step 2
Step 3 Preview the lost files and select the one(s) you prefer > Click the Download to Computer or Download to Device button on the bottom right corner to begin the process.
How to Recover Data from Android after Factory Reset – Step 3
As you can see from above, PhoneRescue for Android can help you easily recover Android data after factory reset. So, why not give it a try now, the sooner you turn to PhoneRescue for help, the bigger chance you will recover your lost data after factory reset.
PhoneRescue® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
based on 2243 Customer Reviews
