How to Fix: Android Phone Won’t Connect to Wi-Fi
Your Android phone won’t connect to Wi-Fi? Looking for ways to fix the Wi-Fi connection failure on Android? The post here can help you out.
By iMobie | Posted: Mar. 16, 2018, Last Updated: Apr. 18, 2018
Home > AnyTrans for Android > Wi-Fi Connection Failure > How to Fix Android Phone Won’t Connect to Wi-Fi
Nowadays, mobile video turns to be an important part of people’s daily life. With Wi-Fi network, you can watch any videos online on your Android phone as you wish. But if the Android phone fails to connect to Wi-Fi, it would be frustrating that you cannot enjoy the show because everybody knows the online videos swallow your mobile data traffic. So you definitely want to know how to quickly fix the Android won’t connect to Wi-Fi. 7 quick tips are offered in the post, and head to get the details.
How to Fix the Android Not Connecting to Wi-Fi Problem
Tip 1. Toggle Wi-Fi Off and On
On your Android phone, go to the notification area and find the Wi-Fi icon. Toggle it off, wait for seconds and toggle it on again. Allow the phone to search for available Wi-Fi connections and check if the Android not connecting to Wi-Fi problem is fixed.
Tip 2. Turn Airplane Mode Off and On
In the notification area of your Android phone, find Airplane mode and turn it off. Waiting for seconds, you can turn it on again.
Tip 3. Check Whether Bluetooth Is Turned Off
The Bluetooth sometimes conflicts with Wi-Fi. When the Bluetooth is on, Wi-Fi might do not work. So turn off the Bluetooth option and then try to use Wi-Fi again.
Tip 4. Switch Off Power Saving Mode
The Power Saving mode usually refuses your Android phone to connect Wi-Fi since the Wi-Fi connection will drain the battery quickly. So make sure the Power Saving mode is switched off in the Settings menu.
Fix Android Not Connecting to Wi-Fi
Tip 5. Turn Off Smart Network Switch
The Smart Network Switch feature automatically switches your Android phone to mobile data connection if the Wi-Fi is unstable. Thus to fix the Wi-Fi connection failure on Android, go and check if the Smart Network Switch is on.
Step 1 Go to Settings, find and tap the Wi-Fi tab.
Step 2 Tap on More on the top right of the phone.
Step 3 A new box will come up on the screen with details about Smart Network Switch.
Step 4 Tap on Off to stop using the Smart Network Switch.
Tip 6. Forget All Wi-Fi Networks and Start Again
Make sure you have all the detailed information like the Wi-Fi name and the password.
Step 1 Go to the Settings menu of your phone.
Step 2 Find Wi-Fi and hit it.
Step 3 All Wi-Fi networks that you have added to your phone will be listed here. Tap on each of the network names and tap on Forget.
Tip 7. Restart Your Modem
Restart your modem if all the devices connected to the modem are not working. To do this, you must follow the manual that came along with the modem. Depending on the model and type of modem you are using, you may have to follow different steps.
Wish these methods would help you fix your Android not connecting to Wi-Fi problem. And for the better management of your Android devices, a super efficient and easy-to-use Android files manager – AnyTrans for Android is offered for you here. It enables you to transfer files between Android devices, from Android to computer, from computer to Android.
If you have any other possible ways to fix the Android phone won’t connect to Wi-Fi issue, welcome to share with us in the comments below. If you want to better manage your Android phones or tablets, go and get AnyTrans for Android to have a try >
AnyTrans® for Android
The best tool to transfer, back up and manage your Android data: to computer, to another Android device, add from computer.
  • * 100% Clean & Safe
